213rwhp rear mounted turbo tl - Page 5
Page 5 of 5 FirstFirst 12345
Results 41 to 46 of 46
Thread: 213rwhp rear mounted turbo tl
  1. #41
    Superbike Twin allonyelite's Avatar
    Jun 2014
    ohio
    137
    Snowblind
    That is a drag bike i made a turbo kit for.
    The owner lives in the UK.
    I have gotten a tig welder, 3d printer, learn to 3d reander so i can sim my low drag plastics.
    Will be down with my bike in about two weeks.
    The i will be going to Arkansas to go do the Arkansas mile. 🙂 with the stock plastics.
    Turboed tl1000r
    180+hp
    Welbro 255 fuel pump
    Set of 4 Wrx 390cc fuel injectors.
    Aeromotive fuel pressure regulator set to 60psi
    Up graded fuel line to 3/8 hoes
    Inline fuel filter mod, all metal fuel filter.
    T25 turbo
    Pc5 PTI (it comes with a pressure and temp sensor) for a 2002 hayabusa
    Here is a link if you want more info about pc5 PTI
    http://www.powercommander.com/powerc...mmander_v.aspx
    Running on E85
    Emusa 38mm wastegate
    10psi of boost
    generic Blow off value
    oil scavenging pump for the turbo
    upgraded rectifier
    WPS 360 cranking amp lithium ion battery.
    Stock tl1000r engine
  2. #42
    Jun 2014
    ohio
    137
    Quote Originally Posted by CrashB View Post
    What's the rwhp and boost on that thing? Stock motor or modded?
    High s8-low 9s bike. Arp head studs. Stock motor other then the head studs.
    Turboed tl1000r
    180+hp
    T25 turbo
    Running on E85
    10psi of boost
    upgraded rectifier
  3. #43
    Jun 2014
    ohio
    137
    I have been live stream myself working on my bike. If you follow me of facebook or YouTube at Allony's speed. You might be able to see them.
    here is a video of me working on the bike a couple days ago.
    Its me and my brother being goofy while working on the bike and a computer.
    https://youtu.be/UZ8ATuFVhGU
    Hope you guys enjoy.
    Turboed tl1000r
    180+hp
    T25 turbo
    Running on E85
    10psi of boost
    upgraded rectifier
  5. #44
    Jun 2014
    ohio
    137
    Turboed tl1000r
    180+hp
    T25 turbo
    Running on E85
    10psi of boost
    upgraded rectifier
  6. #45
    Jun 2014
    ohio
    137
    Turboed tl1000r
    180+hp
    T25 turbo
    Running on E85
    10psi of boost
    upgraded rectifier
  7. #46
    Jun 2014
    ohio
    137
    ust keeping you guys up to date over here.
    ​​​​​​​https://youtu.be/5_PpGHPZwk0
    Turboed tl1000r
    180+hp
    T25 turbo
    Running on E85
    10psi of boost
    upgraded rectifier
