wiring pic anyone
Results 1 to 7 of 7
Thread: wiring pic anyone
    WSB Pit boss hooti's Avatar
    Feb 2009
    rushden northamptonshire, england
    8,263
    wiring pic anyone
    I've got no rear brake light switch due to dbr rearsets on my R, but for the life of me I can't see where the switch should plug into the loom... Can anyone point me in the direction as to where it is on the bike, what the plug looks like and where it is on the loom. Thanks peeps
    right here goes.........
    Pvm calipers and discs, ebc HH sintered pads. braided hel brake lines. pazzo copy levers. ebc uprated clutch kit. double buble carbon screen. d3 copy grips. hrc clip ons. re-worked front forks. gilles rear sets. bitubo rear shock. powder coated wheels, swing arm, frame. ducati 1198 carbon fibre tail. ducati integrated smoked rear lamp. duc rear subframe. carbon fibre full fairing kit. Carbon fibre chain guard. Carbon racing air box and carbon ram air tubes.16 tooth front sprocket 42 rear. projector lights. sv1000 coils. plus mod. piper cross filter. matthehat tre. Carbon mirrors. Ohlins steering damper. Vans top triple. Carbon fibre tank. Modified headers with carbon scorpion tagma cans. Carbon clock surround
    orange / white rhs under tank
    WSB Pit boss tlsgazza's Avatar
    May 2004
    wellingborough, northants, UK
    5,655
    Ask sparky where he hid it.
    Are you close to getting sorted now hoots.
    I'll have to nip over to see you some time.
    black TL1000Sx, owned from new, 01/08/1998, 86.000 miles.
    Red TL1000sv ,original 97 , bought from my girlfriend when we split owned by us since 2004. 30.000 miles.
    Honda XL500r. 1983. Owned since 1997. 30.000kms.
    r1200gs adventure with 106.000 miles.
    Feb 2009
    8,263
    Cheers Stuart.
    Yes gaz just got it mot'd but failed. Rear reflector missing, headlight alignment, rear side lights / stop lights effecting another lamp ( got integrated lamp unit) so got to fit some other flashers for test.
    I'll get it sorted next week and get it taxed woohoo.
    AMA Pit Boss stu_m's Avatar
    Sep 2006
    hull east yorkshire
    2,067
    WTF! The mot tester checked all that?
    Your using the wrong place
    I haven't had a reflector for years plus my integrated light passes all the time
    Feb 2009
    8,263
    Tell me about it, the bike not stations here are numpties. Didn't mind my loud pipes though, the louder the better were his words.
    Sep 2006
    hull east yorkshire
    2,067
    Most places here are a bit more relaxed
    I once went for an mot and the guy set the computer going pissed off to mess about with a car for half an or so then did my bike in ten mins
