TRE for '97 TLS
Results 1 to 5 of 5
Thread: TRE for '97 TLS
    Superbike Twin tootall's Avatar
    Sep 2013
    Cirencester, glos
    197
    TRE for '97 TLS
    Looking at TRE for my '97 tls, only finding them listed for '98 onwards is this a problem?
    looking at this one
    http://www.ebay.co.uk/itm/TRE-GSX140...14290258&rt=nc
    AMA Pit Boss TLJimmy's Avatar
    Jun 2008
    Masterton New Zealand
    2,684
    If it is for a '98 it wont fit. There was a discussion on this recently - search it out and you'll find you can make an active TRE for about 1$ and a soldering iron.
    Ride it like you stole it.
    TLS CF cans;homemade SATRE;Airbox mod;K&N airfilter;'97 temp sensor mod;Iridium plugs;SV1000Coils;TLR bellmouths;OEM-style smoked screen;HH sintered pads front and rear;Metal Gear rotors;OEM mirror mounts blanked;bar-end mirror;short rear fender with homemade numberplate/indicator bracket;damper mount mod;Riflemans clear clutch cover and 1/5 throttle insert;Barnett clutch springs;Mini indicators;2.5wt oil in stock damper;PC II;Bitubo rear shock;Forks up 5mm with Race Tech internals - 1kg/mm springs, custom shimstack,re-valve, piston and cartridge kit;braided front brake line;billet sprocket cover;charging mod;plus mod;clutch-switch relay by-pass;stainless xhaust studs/brass nuts;welded clutch...
    TLR 'Fighter: https://www.tlzone.net/forums/suzuki-...r-build-2.html
    Jun 2008
    2,684
    Did it for you. Click here https://www.tlzone.net/forums/suzuki-...r-tre-mod.html and read post number 8
    Sep 2013
    Cirencester, glos
    197
    Great thanks,
    so to confirm before I burn the bike/house/neighbourhood down.
    I simply need to cut the red(pink) wire and fit a 6.8k ohm resistor inline?
    This is on a 97 TLS.
    thanks again.
    AMA Pit Boss stu_m's Avatar
    Sep 2006
    hull east yorkshire
    2,067
    Yup that's right
