Clutch Cover
Results 1 to 6 of 6
Thread: Clutch Cover
    Mar 2014
    Blyth Northumberland UK
    34
    Clutch Cover
    Well tonight I took off my clutch cover that I tried to seal when I picked up the TLS and as I thought it looks warped between the bolt holes.....
    I'm waiting for Vandriver to come back to me about a billet cover but getting desperate.
    Is it worth buying a new later model cover or will I be looking at the same leaking problems again.
    Just finished a top yoke/renthal conversion and I'm getting desperate to get out on it.
    push out the sleeves in the bolt holes and file 3/4 mm off them
    rub the cover on a sheet of 120grit wet and dry on a flat surface till its flat.
    push the sleeves back in and put 6mm ID washers under the bolts
    run gasket sealant around the Oring.
    tighten till the bolts are snug.
    Mar 2014
    34
    Cheers Ring In
    I did the sleeves when I originally tried to fix the leak but I will give the wet and dry a go.
    There will be a canny bit to sand down to get it flat but its scrap if I don't give it a try.
    GP Champ rxf610's Avatar
    Georgia, US
    1,746
    Like Stu said the washers are key. That distributes the torque. The newer covers have flared inserts that mimic the washer solution.
    ... listen to Six5 ...
    Mar 2014
    34
    sanded the cover and it looks a lot better just need to fit it with the new gasket.
    What about preferences when fitting the new o ring gasket?
    The manual says coat the o ring in grease but I have read on here clean faces and also oil the o ring.
    If its grease as per the manual surely any high temp grease would work (copper slip?)
    Jul 2007
    brisbane queensland
    221
    copper slip not the best idea in an aluminium engine. corrode one another.
    a non setting sealant is the best bet, sparingly applied
    Tom R
    no fear just means you aint goin quick enough yet
