Name that clutch plate set
Results 1 to 4 of 4
Thread: Name that clutch plate set
    Evil Twin egebhardt's Avatar
    Dec 2013
    San Carlos, CA
    293
    I bought this used clutch set off Ebay for $45.
    I wanted it so I could have a spare clutch set for welding and swapping.
    Since it came with clutch plates, I measured them at 3.3mm thick.
    The metal plates I did not measure.
    Basically, I'm wondering if someone recognized the clutch plate pattern?
    It doesn't look like OEM or EBC. Is it Barnett? Thx.
    Attached Thumbnails Attached Thumbnails Name that clutch plate set-clutch.jpg
    1998 TL1000R Blue White - Sold
    K&N filter, JoeV Airbox Mod, DanosTRE, noPAIR, Yoshimura full, YoshBox ECU Adj 5-10-5, Welded Clutch Center
    2002 TL1000R Blue White - Sold
    BMC filter, JoeV Airbox Mod, 6k8TRE, noPAIR, M4 full system, PCIIIusb, HeadliteSwtch, FanSwtch
    2002 TL1000R Blue White - New 12-30-15
    K&N filter, 6k8TRE, Yoshimura full, YoshBox ECU Adj 5-10-5, Barnett Clutch
    2000 TL1000R Blue White - New 2-6-15
    BMC filter, TRE, Yoshimura Zyclone full, PC2, Barnett Springs, Brembo RCS 19, Braketech IronAxis Rotors, Nissin Calipers, Ohlins Shock, Marchesini 5-spoke, Attack TripleClamps, Ballistic 8cell, Ti rotor bolts, Traxxion Fork and Shock Builds
    Dec 2013
    San Carlos, CA
    293
    Anyone? Bueller?
    Silver Subscriber cyclecamper's Avatar
    Jan 2005
    Chicago, Long Beach CA now Virginia
    7,697
    Maybe Vesrah? Don't look like anything I've seen before.
    Dec 2013
    San Carlos, CA
    293
    Thanks. Im still baffled. I could put them in and see how she goes.
