Strange things happening with my TLR - Page 2
Results 11 to 17 of 17
Thread: Strange things happening with my TLR
    NJD
    NJD is offline
    Superbike Twin NJD's Avatar
    Apr 2003
    Nottinghamshire UK
    171
    Thanks for that
    Oh, one more question, is the only fuel filter on the tlr the one in the tank?
    2001 Blue & White TL1000R
    Mods Completed
    Smart 2G Timing Retard Eliminator ~ K & N Air Filter ~ 1/5th Throttle Insert ~ Scorpion Race Cans ~ Dynojet Power Comander II ~ Topgun Under Tail ~ Powerbronze Hugger ~ Hammerit DB Dark Smoke Screen ~ Ohlins Rear Shock
    ~ R & G Racing Swing Arm Protectors ~ R & G Racing Cotton Reels ~ R & G Racing Fork Protectors ~
    The Wish List
    Gilles Chian Adjusters & Lifters ~ Gilles Rearsets ~ Pazzo Racing Shorty Levers ~
    Evil Twin Jonstorp's Avatar
    Jul 2011
    Oskarshamn, Sweden
    292
    Quote Originally Posted by NJD View Post
    Thanks for that
    Yep, same on TLR and TLS.. Recommend you to do the inline fuelfilter mod when you have the tank open.. And make sure you follow the instructions to the letter when you put back the fuelpump.. Using the correct torque and order when you tighten the bolts are critical.. Clean the surface where the gasket sits thorougly.. And swap the OEM pinch-type hoseclamps to ones that you tighten with a screwdriver..
    TL1000S -97
    Bitubo rear shock, custom undertail, highpipes, hugger, Barnett clutchsprings, Airbox mod, K&N airfilter, inline fuelfilter mod, thermostat mod, Ivans TRE, +mod, charging mod, headlight relay mod, Speedohealer, TLR Brake M/C, Nissin 4-pots front calipers with Goodridge lines.
    NJD
    NJD is offline
    Apr 2003
    Nottinghamshire UK
    171
    Would a fuel pump on the fritz also account for excessive fuel usage too?
    like 50 miles to 12 litres of fuel?
    Mods Completed
    The Wish List
  5. #14
    Dec 2012
    Bucks, UK
    3,454
    Sounds normal for my tiller.
  6. #15
    Jul 2011
    Oskarshamn, Sweden
    292
    Sounds a bit much.. I do approx 160 km on 12 litres.. Thats about 25mpg...
    TL1000S -97
  7. #16
    Silver Subscriber cyclecamper's Avatar
    Jan 2005
    Chicago, Long Beach CA now Virginia
    7,697
    There's an internal filter in each injector. RC Engineering replaces the internl filter too when they recondition your injectors.
  8. #17
    Jan 2005
    7,697
    It seems like 9 out of 10 people can't figure out how to time the cams properly, resulting in a lot of rebuilt TL engines with bad cam timing off half a tooth. So I'd sure check that out.
