Adjusting TPS; way to "zero-in" idle?
Results 1 to 5 of 5
Thread: Adjusting TPS; way to "zero-in" idle?
    Feb 2011
    20
    Planning to adjust my TPS; watched the video, looks easy enough, but I need to baseline my idle beforehand. I played with the adjustment knob when I had starting issues; combined with the fast idle lever I'm at ~1200rpm. But only if I leave the lever on for the duration of my ride; otherwise the bike runs lean and dies, so it's just "bandaided" at the moment.
    My question is, since I don't know where the adjustment knob is realtive to its OEM position, is there a way to "zero-in" with it so I know my TPS adjustments are accurate? I can think to warm up the bike, turn down the lever, and slowly spin the knob until I'm at 1200rpm, but such seems like a crude trial-by-error.
    Any other suggestions? ECM's showing c00 and my plugs/fluids are all new.
    Thanks
    c00 is all good
    adjust the tps and idle together. one affects the other.
    its a game of cat and mouse
    Feb 2011
    20
    So is there a way perferable to what I described for setting 1200rpm? Or is it really as simple as turning off the fast idle and just spinning the adjustment knob either way until it's where I need it?
    AMA Pit Boss TLJimmy's Avatar
    Jun 2008
    Masterton New Zealand
    2,684
    Ride it like you stole it.
    TLS CF cans;homemade SATRE;Airbox mod;K&N airfilter;'97 temp sensor mod;Iridium plugs;SV1000Coils;TLR bellmouths;OEM-style smoked screen;HH sintered pads front and rear;Metal Gear rotors;OEM mirror mounts blanked;bar-end mirror;short rear fender with homemade numberplate/indicator bracket;damper mount mod;Riflemans clear clutch cover and 1/5 throttle insert;Barnett clutch springs;Mini indicators;2.5wt oil in stock damper;PC II;Bitubo rear shock;Forks up 5mm with Race Tech internals - 1kg/mm springs, custom shimstack,re-valve, piston and cartridge kit;braided front brake line;billet sprocket cover;charging mod;plus mod;clutch-switch relay by-pass;stainless xhaust studs/brass nuts;welded clutch...
    TLR 'Fighter: https://www.tlzone.net/forums/suzuki-...r-build-2.html
    Superbike Twin RichTLR's Avatar
    Jun 2013
    Chester/Wales border ish
    200
    1200revs is too low imho, I prefer to run at just under 1500revs at idle........
    Rich
    __________________________________________________ _______
    2001 Blue/White TLR. Just about all metalwork satin black powdercoated! Smart TRE, PCIII,ART cans, K&n Air filter, Fanswitch Mod (thanks to TlrTim), Welded clutch (thanks to Sam) , Plus Mod, braided hoses.
adjusting idle
tps adjustment
