Testing G-pack TRE
Results 1 to 3 of 3
Thread: Testing G-pack TRE
    Superbike Twin Dudz's Avatar
    New Zealand
    169
    Testing G-pack TRE
    Just been on "Steve's TL Pages' and saw this ;
    Testing
    Testing that the unit is working is pretty straight forward. Use a high impedance digital multimeter set on volts DC. On the Pink / Red wire that goes to the ECU you should get the following readings down to ground.
    In neutral, close to 5.08VDC
    In all gears using a 15K resistor, close to 4.70VDC
    In all gears using a 6.8K resistor, close to 4.38VDC
    Make sure you test the circuit -if the circuit is open the ECU reverts to a neutral map = yuck!
    Tested my G-pack thismorning, as it was on the bike when I bought it.
    In Neutral it reads 5.07V between the red wire and earth.
    In 2nd gear it reads 0.68V . Engine running in both situations.
    Does anyone know if these readings are good please ?
    I am hoping its knackered So I can actually get more out of the bike.
    TLS (2000) . Air box mod / PCIII / Bitubo rear shock / K&N Filter/ G-Pack/1997 UK ECU/ Hydro clutch mod/ Streetfighter headlight unit/ Aftermarket cans / GSXR1300 forks with radial calipers/ Sam's welded clutch center and F.Disc spacing kit/ Vanzuki CCC. My own custom top Billet triple. Rear subframe and cans by Alonso at TBS factory France
    New Zealand
    169
    The G-pack for the Tl should be 6.8k So Ive read.
    My mistake.....Tested the wrong side of the G-pack.
    4.7V in Neutral
    3.55V in 2nd and 3rd gears
    GP Champ rxf610's Avatar
    Georgia, US
    1,746
    Dudz,
    The ECU gear breakdown is as follows:
    1st gear = 1.782v
    2nd gear = 2.242v
    3rd gear = 2.960v
    4th gear = 3.630v
    5th gear = 4.310v
    6th gear = 4.660v
    Neutral = 5.000v
    So you are closer to 4 than 3 and probably should be fine. Oh and thanks again for the map info!
    ... listen to Six5 ...
