Stator Question
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By 1hero41
Thread: Stator Question
    Baby Twin 1hero41's Avatar
    Mar 2014
    11
    Stator Question
    Hey what's up guys. I just found out that my bike needs another stator.
    I've been shopping around and found a few, but some have what is called a "Stator Pulser Trigger Coil" connected to it where you also don't need to nip the 3 wires and attach them to the connector for the Voltage Regulator. Others don't have the Stator Pulser Trigger Coil, but you do have to attach the 3 wires to the connector yourself.
    What does the Stator Pulser Trigger Coil do, and does it matter whether I purchase a stator with or without one?
    Thanks guys
    GP Champ rxf610's Avatar
    Georgia, US
    1,746
    It takes in a pulse from a small electromagnet, relays that to a CDI, which creates spark. It is a timing mechanism. The ECU handles the timing pulse to the the coils, a la our TLs don't have them.
    ... listen to Six5 ...
    YES they DO!
    Georgia, US
    1,746
    Listen to Stu. Period. I'm an armchair quarterback. At best...
    I should have said our TLs don't have CDIs. Not implied they don't have pulse triggers.
    problem is right now that they are coming to the age where they are becoming problematic.
    i replaced one last week and have replaced maybe 4 over the last 2 years.
    they may throw a c12 code or none at all but its symptomatic of bad running and misfire.
    choose a replacement with a trigger if its offered and play safe for the future
    Mar 2014
    11
    I pulled the Stator out finally to return it to Ricks. They told me the reason it failed was there was a foreign object that was in under the stator cover that caused the damage which made it short out(I did see lil metal pieces which probably came from the old stator). Idk what happened, but I'm gonna do it myself to make sure it's done right this time. Should there be a magnet located in the area where the stator and flywheel goes? The mechanic who installed my returned stator said there was supposed to be one (I don't think there is, because the flywheel itself is magnetic.) Also, do I tighten the stator bolts and stator cover bolts down as tight as I can get them with a tool? The same mechanic told me to hand tighten them which I doubt that is correct also. I'll be going to the dealer from now on to be sure though.
    Mar 2014
    11
    You're right.. I pulled the cover to remove the stator and found that too.
    duc1986 likes this.
