First ride on my 97 tls today everything was fine to start with and then it started to stall so got it home and now it won't start there's no idiot lights except the neutral light any ideas
Seeing as how you are in a humid climate, it may be a matter of corroding terminals. Specifically, the large white gang connector (the Orange wire to Black/Red wire connection). Open the connector housing and inspect the condition of the terminals. Clean them as best you can - with contact cleaner or WD-40.
While you have things apart, it would be good to check the Yellow and Black connectors also.
@ shooter,
Cut the single spade connector out of that ground wire and solder the wires directly together. This provides a much improved ground connection. :thumbup
Whilst your in the mood for fettlin' 'lectiks ... pull the yellow and white conn blocks anyway and clean them. I stripped the terminals from the blocks and checked them thoroughly. Gives you added peace of mind.
Related Threads
TLZone Forums
1.3M posts
31.8K members
Since 2003
