fuel pump wont prime on tl1000s - Page 4
Page 4 of 4 FirstFirst 1234
Results 31 to 32 of 32
Like Tree5Likes
Thread: fuel pump wont prime on tl1000s
  1. #31
    4,035
    Quote Originally Posted by Hotspotuk View Post
    UPDATE!!!!
    .... still no spark or fuel pump working. Tested and checked all connections then checked ignition switch with a problem there being no continuity between the White/Orange and Black/white wires so that's now on order ....
    How is it that you are expecting to see continuity between the Orange/White and Black/White wires when the Org/Wht wire does not enter the ignition switch? Or did you intend to say "Orange/Yellow" wire?
    If so, know that there is 100 ohms resistance between the Org/Yel wire and Blk/Wht wire built into the switch when the key is in the ON position. It will not be a "zero ohm" connection.
  2. #32
    Dec 2015
    42
    Source of the problem after replacing the wiring loom was the ignition switch dry connections, I soldered the points again inside the switch and that was problem solved
    Yup orange/yellow lol!
1997 tl 1000 new fuel pump not priming
1997 tl1000s fuel pump not working
2001 suzuki tl1000r problems not starting
problems starting tl1000 after replacing fuel pump
suzuki tl1000 fuel pump doesnt kickon
tl 1000 fuel pump relay
tl 1000r can not hear fuel pump priming
tl1000s fuel pump
tl1000s fuel pump problems
tl1000s fuel pump relay
tl1000s fuel pump wont prime
tl1000s relay
