fuel pump wont prime on tl1000s - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
Like Tree5Likes
Thread: fuel pump wont prime on tl1000s
  1. #21
    4,033
    Quote Originally Posted by Hotspotuk View Post
    The 2nd ECM was an eBay unit
    The reason I asked is with an eBay ECM you really don't know the history on it either. Even if the seller says "it came from a running bike" that's no guarantee that it is fully functional. Often, when the fuel driver transistor fails, riders will just jumper the fuel relay (Orange/Wht to Yellow/Red) so that the fuel pump runs whenever the key is on. The system works and it is rideable. Then when the TL get parted out, the ECM is sold on eBay as 'fully functional' because the bike was running, when it actually has a failed fuel output driver (for the Yel/Blu wire).
    It is a possibility, but you won't know until you go through all the tests.
    Problem is I have no history of this bike, ..... don't really want to do too much til I have the teething problems sorted.
    Understandable.
    Did you try the TOS test The Ring-In recommended?
    Hotspotuk likes this.
  2. #22
    If you are going street fighter I have most of the things you need for the conversion
    the gauges are easiest using R gauges
    I have dash panel and converters to suit
    also have polished triples and handlebar setup etc
    Get it running then let me know
  3. #23
    Dec 2015
    42
    seems strange that the kickstand switch doesn't seem to do anything I mean with stand up or down the relay still clicks and engine turns over
  5. #24
    Dec 2015
    42
    TOS switch if fine
  6. #25
    4,033
    Follow the wire into the loom and you'll likely find that the switch has been bypassed.
  7. #26
    Dec 2015
    42
    Replaced loom and the fuel pump primed, went for a cuppa and tried again and now bloody thing not priming again
  8. #27
    4,033
    So, you replaced the entire loom?
    It is a good sign that the pump primed - at least once. That confirms the ECM is doing it's job.
    Apparently, there is an intermittent open (or high resistance) in the circuit somewhere (if no error codes are showing up).
    Can you verify that the ECM is being powered up consistently each time? (It's not showing "CHEC" in the LCD window, correct?)
  9. #28
    Dec 2015
    42
    I don't have the original clocks to verify any error codes, previous owner fitted aftermarket speedometer
  10. #29
    4,033
    Oh yeah, how soon I forget.
    So then, without the ability to see the error codes, you are back to where you were before the loom change. It is acting as though the ECM is prevented from priming the pump due to a lack of sensor feedback.
    Since you say the TOS is fine, the only other sensors that can inhibit the fuel pump command are the crank position sensor and the cam position sensor (IIRC). Check out those two circuits the best you can - all the way back to the ECM. You may even want to remove the rear cam cover to verify that the sensor pin has not fallen out of the cam. It has happened to others.
  11. #30
    Dec 2015
    42
    UPDATE!!!!
    Built bike back up again and now no spark or fuel pump so went back to testing everything with multimeter.
    New regulator needed so that got installed and still no spark or fuel pump working. Tested and checked all connections then checked ignition switch with a problem there being no continuity between the White/Orange and Black/white wires so that's now on order and hopefully have it next week
    New HT leads getting fitted and serviced with plugs and oil also
1997 tl 1000 new fuel pump not priming
1997 tl1000s fuel pump not working
2001 suzuki tl1000r problems not starting
problems starting tl1000 after replacing fuel pump
suzuki tl1000 fuel pump doesnt kickon
tl 1000 fuel pump relay
tl 1000r can not hear fuel pump priming
tl1000s fuel pump
tl1000s fuel pump problems
tl1000s fuel pump relay
tl1000s fuel pump wont prime
tl1000s relay
