removing RAM Air system - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 34
Thread: removing RAM Air system
  1. #21
    AMA Pit Boss tillerdog's Avatar
    May 2007
    grants pass or
    2,340
    yep
    once i thought i was wrong but i was just mistaken!!
    if yer bored as hell look at my ebay store !!
    http://stores.ebay.com/onanysunday711
  2. #22
    GP Champ Schiben's Avatar
    Apr 2009
    Hartfod, WI
    1,014
    Would having a different diameter or being made out of a differen't material make a difference? I assume some calculations would have to be made. Do sharkskinz TLR tubes actually provide any improvment?
  3. #23
    MotoGP Pit Boss Toledo's Avatar
    Jul 2005
    Kent, UK
    11,556
    I wouldn't think material "type" would make any difference but siz/bore, length & shape yes.
    Mark.
    TLOTM JULY '11
    People I will not deal with: tl1000s/tl1000r Will/2012-krystal or whatever he decides he might/might not call himself.
  5. #24
    MotoGP Pit Boss Chris's Avatar
    May 2009
    South Staffs/ Shropshire border
    11,780
    You aircraft numpty's should know material and air flow go hand in hand Mr Toledo.
    Enter the golf ball dimple argument.... if the golf ball has no dimples it doesn't travell as far
    Rough and smooth surfaces give differing turbluance....
    So... materials would make a difference.... might only be a smalll one though.
  6. #25
    Jul 2005
    Kent, UK
    11,556
    Only the surface finish Chris...........dimples would create drag/turbulance. I took it as material spec'.
    Mark.
    TLOTM JULY '11
  7. #26
    May 2009
    11,780
    Quote Originally Posted by Toledo View Post
    Apparently not... they create a barrier OF air between the surface and the moving air..... allowing the air to pass over without drag..
  8. #27
    Jul 2005
    Kent, UK
    11,556
    You're talking about laminar airflow
    Mark.
    TLOTM JULY '11
  9. #28
    May 2009
    11,780
    Fuck knows
    I don't like google
  10. #29
    AMA Pit Boss Loki-TLR's Avatar
    May 2006
    Netherlands
    2,665
    When moving air is stopped it will pressurize slightly wouldn't it?
    JMCA 00139160
  11. #30
    May 2007
    grants pass or
    2,340
    Quote Originally Posted by Loki-TLR View Post
    i think your rite,it is called fluid dynamics,alltho a fluid is non-compressible as where a gas is...so a gas that is flowing in a tube and then is restricted,carries enegy thru inertia to compress which can raise pressure and speed of flow or both..fuk that hurts.gotta aspirin ?? but our bikes do not get efficient use of ram air unlees your riding 100+ fukall miles an hour,on the street ? are you kiddin' me fukin ram air is the least yer probs you need to hire an undertaker.that said the sound wave deal is seperate from ram-air
01 gsxr ram air seal
04 gsxr 600 ram air ducts install
08 gsxr ram air delete kit
1000 gsxr k6 ram air noise
gsxr 1000 ram air effect
gsxr 1000 ram air tube mod
gsxr ram air remove
gsxr ramair tubes foam
how to install 2003 gsxr ram air ducts
how to make bike ram air tube
tl1000s ram air
tl1000s ram air map
