Swingarm removal help
Results 1 to 4 of 4
Thread: Swingarm removal help
    Superbike Twin thumpick's Avatar
    Aug 2009
    Heysham (UK)
    145
    Hi,
    Was wondering if the castle nut on swingarm is left hand thread or not ?
    Don’t fancy tugging away in the wrong direction.
    Cheers
    normal thread
    Mar 2013
    South East Wales
    2,688
    If you can borrow an impact gun then it makes castlenut removal significantly easier. I found it almost impossible to remove it with a socket wrench, but that could be down to technique.
    Aug 2009
    Heysham (UK)
    145
    Excellent, thanks for advice. Swingarm now off and ready for refurb.
