Starter motor help needed
Results 1 to 4 of 4
Thread: Starter motor help needed
    Baby Twin FlashHarry's Avatar
    Apr 2016
    Bristol
    Hi guys been stripping my starter motor and found a crack in the magnets on the inner sleeve. Will this make any difference to the starter ? Also after cleaning it and re assembling the starter shaft if very hard to turn by hand is that correct or have I over tightened something?
    Cheer gents
    4,046
    Quote Originally Posted by FlashHarry View Post
    My guess....
    A cracked magnet will be a problem. I don't know exactly how the magnets are configured in these starter motors, but if the fracture goes through the core material, it will create another two poles in the magnet that were not originally there. For instance, given a single piece two pole (north-south) magnet: break it in half, now there are two magnets - each with its own north and south poles. What used to be a north-south pole sequence in the motor's rotation, is now a north-south-north-south sequence.
    So then, if the fracture is significant, it could create a condition that works AGAINST the normal rotation of the motor, or at the very least, will make it weaker and less efficient.
    I can't say for sure if the difficulty in manually spinning the motor is due to the magnet change or your reassembly. May want to check your work....
    I wouldn't condemn the magnet just yet.
    they are glued into the case so they will retain the magnetic integrity that they need.
    if the magnet has come loose it may be rubbing on the armature .
    more likely is that you have not assembled the case ends correctly. they only fit in one orientation
    if you look closely you should find a line or mark to align on each part.
    take it apart again and don't make any assumptions. check every step as you go
    Apr 2016
    Bristol
    Thanks gents . I’ll strip it and check it over again . The magnet was still in place but may of drifted off the housing after re assembly.
