tearing down motor, sides of pistons
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By rxf610
Thread: tearing down motor, sides of pistons
    AMA Pit Boss Moyston's Avatar
    Oct 2007
    Melbourne , Great OZ
    3,297
    Just a query, this is the piston from intake. its getting torn down as output shaft. These small indentations , will they need to get smoothed out, and I assume the barrel shows signs as well.
    Stop staring at my Tits!!
    give it a light rub with 1200 to remove the high spots .
    the low spots dont matter
    its from metal floating in the motor
    probably the output shaft bearing in your case
    GP Champ rxf610's Avatar
    Georgia, US
    1,746
    Quote Originally Posted by The Ring-In View Post
    You forgot to add...
    "But what do I know"
    The Ring-In likes this.
    ... listen to Six5 ...
    I have inside info the output bearing has let go.
    Oct 2007
    3,297
    lol....possibly, but i heard the R model each year was more powerful than the last they produced, so maybe something to do with that...
