What is best tolerance at big end oil clearance? manual say standard clearance @ tlr crank is 0.040-0.064mm i calculate now 0.052mm
what are you opinion at clearance? my are now half way at standard. but maybe if i go step down near 0.060mm i get more oil and rods are happier:laugh or its there matter its only 8thousand, just curious
Ok, what about sv shells on tl rods? i have carillo rods and there is no that oil escape hole drilled, oil just spread both sides. i read sv shells are wider and dont have that hole middle of shells, but what about bearing codes? and are they too wide for tl crank?
SV shells could be fitted to TL rods but I wouldn't recommend it. You would need to file the locating tangs which isn't too bad but the TL rods have a much larger chamfer on the outside edges and the SV shell would be unsupported at that point.
yep, everything go so far as i plan, cleaning inspect now assembly. only just long wait time that crankshaft they had very busy at work. a little late time schedule. and maybe is everything go good a 1 or 2 horsepower may find irate6
Related Threads
TLZone Forums
1.3M posts
31.8K members
Since 2003
