TLR - Suspension Squeaking - Page 2
Results 11 to 19 of 19
Thread: TLR - Suspension Squeaking
    WSB Pit boss tlsgazza's Avatar
    May 2004
    wellingborough, northants, UK
    5,651
    The rotary damper is just a damper. No springing to hold it up.
    Glad stu came in. I did wonder if it would be the same for the R .
    black TL1000Sx, owned from new, 01/08/1998, 86.000 miles.
    Red TL1000sv ,original 97 , bought from my girlfriend when we split owned by us since 2004. 30.000 miles.
    Honda XL500r. 1983. Owned since 1997. 30.000kms.
    r1200gs adventure with 106.000 miles.
    Aug 2014
    San Antonio, Texas
    1,759
    Quote Originally Posted by tlsgazza View Post
    ... I did wonder if it would be the same for the R .
    I knew the Damper was slightly modified on the R to allow for better oil flow at high temps, but had no idea the SOAS was different.
    Learn something everyday.
    Baby Twin Chops's Avatar
    Feb 2017
    6
    Check swingarm too. My TLS swingarm pivot broke. Not sure if this is a problem on TLR.
    Look-up:
    "Suzuki tl1000s Swingarm Failure"
    On TLPlanet
  5. #14
    chops tlr arm not a problem. different construction and different load bearings
  6. #15
    4,043
    Quote Originally Posted by JoshCampbell View Post
    That being the case, I will definitely need to source a new linkage, as I was overly generous with the moly grease when I reassembled the unit.
    Josh, don't source any new linkages before you inspect and lube the top pivot mounting of the SOAS. Ask me how I know.
    Years ago, I found myself in a situation nearly identical to yours. At the time, I had just had the rear end of the TLR taken apart. All of the linkages and bearings were lubed. Roughly two weeks later a squeak developed. It was very difficult to discern the source of it while sitting on the bike, but that was the only time it would squeak. It turned out to be the top pivot of the SOAS.
    I never thought I would need to relate that story, but there you go. Hopefully, it helps you or someone.
  7. #16
    Aug 2014
    San Antonio, Texas
    1,759
    Actually I'm still debating whether or not to do any further inspection of the SOAS. Since the day I sprayed some WD-40 along the shaft the noise has not returned.
    NOTE: I did lube the upper SOAS bearing prior to reassembly. I lubed everything on Clyde. lubed it like Buffalo Bill.
  8. #17
    Dec 2012
    Bucks, UK
    3,454
    There is another way to fix all of this.
  9. #18
    Aug 2014
    San Antonio, Texas
    1,759
    Quote Originally Posted by snowblind View Post
    There is another way to fix all of this...
    Good point Snowy... Yellow paint makes everything better
    [IMG class=inlineimg]/forums/images/smilies/baaa.gif[/IMG]
    [IMG class=inlineimg]/forums/images/smilies/ytiller.gif[/IMG]
  10. #19
    Superbike Twin Mikeblue's Avatar
    Oct 2018
    ST Helens, Northwest England
    152
    I can feel a winter project coming on, he he he.
    Blue and white ones are faster
