Remote engine start - Page 2
Results 11 to 15 of 15
Thread: Remote engine start
    Evil Twin Juzz976's Avatar
    Nov 2010
    Tauranga, NZ
    425
    Note this setup you'll need to have the ignition turned on and the killswitch closed. This is how I have done a setup for warming up in the morning b4 work. Although the immobiliser cut ign supply so battery didn't drain.
    I have done a setup for remote start that bypasses the ignition and killswitch untill the sidestand is lifted but requires some electronics work. Or an additional relay or 2.
    How would you like yours to operate? I can make another drawing.
    Carbon TL1000R-W : OYA CF Fairings, Stubby KENZ full stainless system, Kent cams, PAIR removed, Airbox Mod, K&N Air filter, TRE, Custom GPI Coulour coded, Gap Mod, Racetech fork valves,
    06 R1 Rear Shock + 1100lb Ohlins, Polished bits, Bar end mirror, Projector Lights, LED Indicators, Nology Hotwires, remapped ECU, aluminium hugger, Vanzuki: Rear brake res, return spring, spring seat stem nut. Wezmoto blue braided lines, barnett clutch kit.
    Aug 2012
    Monterey Co.
    6
    Hey juzz976, I have a question. I just got the alarm I ordered and instructions that came with it. on the wiring diagram everything looks pretty straightforward. I see where I'm cutting the big brown wire from the starter that is the engine cut off. There is a blue wire they show me connecting to the (CDI) capacitor discharge ignition? I'm little unsure where that is now besides those 2 wires I don't see how the remote engine start is going to work without something triggering the FI system. When I get home I can upload a copy of the wiring diagram so you can see what I'm talking about. You can also find a copy online. Just google Spy alarm 5000M wiring diagram. I have a few friends that have this alarm installed on their bikes with FI. But they took their bikes to the shop and had them installed so they have no idea how it Is installed on thier bikes. Any advice you can give as usual would be greatly appreciated.
    Nov 2010
    Tauranga, NZ
    425
    You should not be disconnecting any large wires. Alarms, immobilisers and remote starters all work on control wiring not power wiring.
    You have a few options,
    interrupt the starter relay coil - can still be roll started.
    inerrupt the ignition from their feed or drian wires. a TL1000R is O/W feed and the 2 coils so interrupt before the split means only one contact is required.
    Other ways is to go inline to kill switch, fuel pump relay or CDI supply.
    I prefer to interrupt both Fuel pump relay and Starter Relay.
    What model bike you installing it on?
  5. #14
    Aug 2012
    Monterey Co.
    6
    02 TL1000R. I have the picture of the instructions on my cell but it won't let me upload it. I can send it to your email if that's ok.
  6. #15
    Aug 2012
    Monterey Co.
    6
    Ok Juzz976 heres a copy of the wiring diagram that cam with the alarm
    Attachment 36495
    The black and white goes to the CDI? From what i have read online, everyone says these instructions are for Sh*t. And my bike is a 02 TL1000R. Thanks in advance.
    Attached Thumbnails Attached Thumbnails Remote engine start-20120820_143655-1-.jpg
installation spy 5000m engine off
remote engine starter
spy 5000m remote start 06 r1
spy alarm 5000m
