| What I learned today Post it here to help others from having to learn it the hard way. Please limit it to bike related threads. |
09-15-2008, 10:51 PM
#21 (permalink)
Que?
Member #4632
Life Wasted on TLZone: 2 Months, 0 Weeks, 3 Days and 4:02:58 Hours
Kamikuza
's real name is Kevin
When I rebuilt my old calipers, I had to take them to the bike shop to get them to pull out the pistons  the bastards just wouldn't shift, no matter what I did ... they used the funky pliers and had them out in seconds.
The tosser who said "A poor workman blames his tools" obviously had a bloody shed full of the right tools for the jobs ... I've probably said that before though
09-17-2008, 02:36 AM
#22 (permalink)
Member #14541
Sportsbike: 3/97 TL1000S
Riding Experience: 24yr+time off 4 bein bad
Life Wasted on TLZone: 1 Month, 0 Weeks, 5 Days and 11:44:50 Hours
TLJimmy
Loves Boobies and Bikes
I think the idea is that a poor workman has poor tools, wrong tools or no tools  ; and a good workman makes sure he has the right tools for the job, BEFORE he starts said job. Wanker. The rest of us poor slobs make do as best we can  .
Ride it like you stole it.
From Randy's pages:
...Newbie riders should simply skip the TL and go straight to the morgue.
Mods done: 2 Bros mufflers;homemade TRE;Airbox mod;'97 temp sensor mod;Iridium plugs;TLR bellmouths;OEM-style smoked screen;HH sintered pads front and rear;Metal Gear rotors with gold carriers;removed OEM mirrors and mounts;bar-end mirror with cut down stock weight as spacer; chopped rear fender; DID gold x-ring heavy duty chain;2 up on rear sprocket;damper mount mod for easy tank lifting;forks up-in-the-triples 7.5mm;Riflemans clear clutch cover and 1/5 throttle insert;Barnett clutch springs;Mini CF look indicators front; mini chrome LED's rear with resister;2.5wt oil in stock damper;PC II;Bitubo rear shock;Forks - Race Tech internals with 1kg/mm springs and Gold valves;braided front brake line;billet sprocket cover;charging mod;plus mod;
To do:TLR MC;black; paintTLR swingarm;chequer plate undertail;6 pot brakes;inline fuel filter;hotgrips
09-17-2008, 09:18 AM
#23 (permalink)
Member #9870
Sportsbike: 2001 TL1000R
Pictures: 15
Life Wasted on TLZone: 1 Week, 4 Days and 12:29:04 Hours
keeena
A little compressed air into the hydraulic line fitting and those stubborn pistons will eagerly jump out of the caliper in a quite spectacular fashion.
09-17-2008, 05:25 PM
#24 (permalink)
Que?
Member #4632
Kamikuza
Didn't have a compressor at that stage ... now I have one and it don't work
I tried using a bicycle pump but didn't have enough hands, arms or legs.
09-17-2008, 08:48 PM
#25 (permalink)
Member #6676
Sportsbike: '98 TLR
Riding Experience: twice a year
Life Wasted on TLZone: 2 Weeks, 6 Days and 6:01:53 Hours
Patch11
Patch
just stick ya lips round the hose man and blow like fuck - should be no problem for a man of your talent
The idea is not to buy cheap but to buy right!
09-17-2008, 09:03 PM
#26 (permalink)
Que?
Member #4632
Kamikuza
Blow? Not suck? So that's what I was doing wrong ...
09-18-2008, 11:40 AM
#27 (permalink)
Member #7563
Sportsbike: TLRS
Riding Experience: not enough
Life Wasted on TLZone: 2 Weeks, 4 Days and 0:21:30 Hours
Loki-TLR
Loki-TLRS
I had the same problem, was making a ghetto tool but haven't tried it yet!
Fwiw: it's made from steer-end thingy. The rubber that goes in the steerer tube goes over a bolt. It can be compressed with a nut.. around the rubber I filled up to meet the inner piston diameter. I can create quite some friction with it, I reccon it should be enough to get pistons out that aren't stuck!
The coolest car alarm tester by far - TL1000S
10-18-2008, 04:59 AM
#28 (permalink)
Member #15801
Sportsbike: TLs, DR600, Lc4, Zundapp and Folies
Riding Experience: 19 Years across Europe
Pictures: 7
Life Wasted on TLZone: 19:09:47 Hours
sta
Stanleysantiagoson
What's the name of the Funky brake piston pulling pliers?
I want one
10-18-2008, 06:27 PM
#29 (permalink)
Que?
Member #4632
Kamikuza
Dunno, they are generic brand at the local generic Taiwanese import tool shop  about US$15
If you take the pads out, they're 'short' enough to get into the pistons and wiggle them around (for cleaning) without having to split the caliper, too
02-18-2009, 09:41 AM
#30 (permalink)
Member #14355
Sportsbike: 98 suzuki tl1000r
Riding Experience: 7 years
Life Wasted on TLZone: 2 Days and 16:30:08 Hours
dave tlr
will try your idea as just after a clean up really and didnt want to fully stip calipers if at all poss unless they are siesed dont ride in the wet so hope that helps just one thing you mention greasing pistons after cleaning will copper ease be ok for this as have some of this already in garage and moneys a bit tight at the mo
