| What I learned today Post it here to help others from having to learn it the hard way. Please limit it to bike related threads. |
07-30-2008, 05:11 AM
#11 (permalink)
Member #14541
Sportsbike: 3/97 TL1000S
Riding Experience: 24yr+time off 4 bein bad
Life Wasted on TLZone: 1 Month, 0 Weeks, 5 Days and 11:44:50 Hours
TLJimmy
Loves Boobies and Bikes
Originally Posted by vandriver
Warm soapy water is fine. Do not use brake cleaner, it attacks rubber.
 Good to know.
Ride it like you stole it.
From Randy's pages:
...Newbie riders should simply skip the TL and go straight to the morgue.
Mods done: 2 Bros mufflers;homemade TRE;Airbox mod;'97 temp sensor mod;Iridium plugs;TLR bellmouths;OEM-style smoked screen;HH sintered pads front and rear;Metal Gear rotors with gold carriers;removed OEM mirrors and mounts;bar-end mirror with cut down stock weight as spacer; chopped rear fender; DID gold x-ring heavy duty chain;2 up on rear sprocket;damper mount mod for easy tank lifting;forks up-in-the-triples 7.5mm;Riflemans clear clutch cover and 1/5 throttle insert;Barnett clutch springs;Mini CF look indicators front; mini chrome LED's rear with resister;2.5wt oil in stock damper;PC II;Bitubo rear shock;Forks - Race Tech internals with 1kg/mm springs and Gold valves;braided front brake line;billet sprocket cover;charging mod;plus mod;
To do:TLR MC;black; paintTLR swingarm;chequer plate undertail;6 pot brakes;inline fuel filter;hotgrips
07-30-2008, 02:07 PM
#12 (permalink)
Que?
Member #4632
Life Wasted on TLZone: 2 Months, 0 Weeks, 3 Days and 5:56:43 Hours
Kamikuza
's real name is Kevin
Then why is it for cleaning brakes?
07-30-2008, 02:54 PM
#13 (permalink)
Banned
Member #3727
Riding Experience: 20
Life Wasted on TLZone: 2 Months, 3 Weeks, 5 Days and 6:04:06 Hours
vandriver
Because they think you are going to disassemble them, to work on them.
Read the can.
07-30-2008, 03:17 PM
#14 (permalink)
Member #11457
Sportsbike: 1998 TLR Blue
Riding Experience: 10 yrs
Life Wasted on TLZone: 2 Weeks, 0 Days and 4:18:06 Hours
WillyB
Read the can.
Yeah, read the can Jackass
09-01-2008, 05:41 PM
#15 (permalink)
Que?
Member #4632
Kamikuza
 dude, check my location - the can's all written in Japanese and I don't read that so good
Send me an English can, I'll be happy to follow the instructions
09-11-2008, 01:08 AM
#16 (permalink)
Member #15483
Sportsbike: 2003 TL1000R
Riding Experience: bout 5 years
Life Wasted on TLZone: 3 Days and 15:03:41 Hours
GeeLedouche
I'm not exactly clear on how to do this.. anybody want to clarify please? so ya take the pads off, and put the socket in between 2 of the 6 pots and pull the brake lever to push the remaining 4 pots towards each other, then just scrub them down with the soapy water with a tooth brush or something?? then push the pots back in and do it again to the pots that were compressed? can you do it to the rears also? thanks for the clarification guys..
Gee
09-11-2008, 04:00 PM
#17 (permalink)
Member #15621
Life Wasted on TLZone: 4:02:11 Hours
EBC Brakes
↑ correct just dont forget to grease the pistons when putting them back.
09-15-2008, 08:31 AM
#18 (permalink)
Member #12521
Sportsbike: TL 1000 s
Riding Experience: 25 yrs
Pictures: 2
Life Wasted on TLZone: 1 Day and 0:03:22 Hours
Mac
yep, thats it m8, though with six pots you would prolly find it easier to place the socket so it holds four in place whilst you pump the other two out.
i just did it at the weekend for a m8's rsv........he he he couldn't believe the difference
Improvise - Adapt - Overcome
Come to the Dark side
We have cookies.....
09-15-2008, 07:31 PM
#19 (permalink)
Que?
Member #4632
Kamikuza
I did this yesterday cos it was pissing rain during my planned riding time
I'd already greased the pistons but put some WD-40 in there (finally found some!) and rotated the pistons, cleaning off the gunk and excess grease. I bought a pair of brake piston pulling pliers ages ago - bloody great tool! Like pliers but with a round, gnurled half-cylinder on the end. You put the gnurled bits inside the piston, clamp down on the handles and you can lift, rotate, push the piston around ... they're all moving free now  and together.
I also did the "caliper bolts finger tight, brake on, tighten bolts" to center the pads ... no more clacking pads
09-15-2008, 10:16 PM
#20 (permalink)
Member #15483
GeeLedouche
awesome! thanks guys. I definatly see this in the future for my rig.
