Bump starting your bike...BAD??? - TLZone Forums
Go Back   TLZone Forums > General Forums > What I learned today
What I learned today Post it here to help others from having to learn it the hard way. Please limit it to bike related threads.
Old 01-12-2008, 07:30 PM   #1 (permalink)
Bikenamspike's Avatar
Member #12315
Sportsbike: 99 TL1000R
Riding Experience: 3 YEARS
Pictures: 5
Life Wasted on TLZone: 1 Day and 20:02:32 Hours
Bikenamspike
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Bikenamspike<!-- google_ad_section_end --> Steve is the prettiest admin
Crazy what I heard today. I learned that you should not bump start your bike with the car running. The car or automobile has too much power running through the wires that could burn out your Stator, Flywheel, Starter Motor, Relay,Rectifier and/or altenator. If that is wrong... Please Correct me. I need all the info I can get.
Kelly
Outside Fuel Filter System MOD... New battery...New selonoid...new "ZERO" windscreen...new CR9EK plugs...new DOT4 brake fluid...new LED mirrors...new Stock clutch,rear and front brake levers...new grips... ...had a new smile until I found I still have OLD problems. HELP!!!!!ThanX Kelly is the name... "Spike" is my Bike. Check The Garage.
Old 01-12-2008, 07:33 PM   #2 (permalink)
haiiro99's Avatar
Member #2881
Sportsbike: '00 ZX6R (Trackbike)
Riding Experience: Since '99
Trader Rating: (7)
Life Wasted on TLZone: 1 Week, 0 Days and 3:55:28 Hours
haiiro99
Send a private message to <!-- google_ad_section_start(weight=ignore) -->haiiro99<!-- google_ad_section_end --> Steve is the prettiest admin
I've tried this a couple of time along with jump starting a Suzuki mini 4x4 (a grand vitara) with the TL.
Not something you'd want to do too often though..
Brown man in a white van
Old 01-12-2008, 07:38 PM   #3 (permalink)
Member #12315
Pictures: 5
Bikenamspike
What do you think I burned out? Im having this problem NOW!!! I want to know exactly what I should check out. I've check the Starter Motor to find that thats fine? What should I check out
Old 01-12-2008, 07:43 PM   #4 (permalink)
haiiro99's Avatar
Member #2881
Trader Rating: (7)
haiiro99
I'm not too sure, but I'd try the main fuses as well. It could be something simple like that or something more complicated like the other parts you mentioned. It might not burn the flywheel.. cos I don't know how you'd burn one of those...
I'm sure the guys here who know more than I do will pipe in as well.
Old 01-12-2008, 07:48 PM   #5 (permalink)
Member #12315
Pictures: 5
Bikenamspike
thanks ...
Old 01-12-2008, 08:05 PM   #6 (permalink)
haiiro99's Avatar
Member #2881
Trader Rating: (7)
haiiro99
NPs.. what's actually happening? Is there no power at all or is it not firing?
EDIT: just saw your other thread. Got me stumped..
Old 01-12-2008, 08:09 PM   #7 (permalink)
Member #12315
Pictures: 5
Bikenamspike
Well.... Im getting it to start but it relies on the battery to stay running. I can not get it to start on its own anymore. And my brand new batteries die as quick as a week when I ride. SOMETHING having to do with keeping the battery charged during riding has to be the problem.
Old 01-12-2008, 08:23 PM   #8 (permalink)
haiiro99's Avatar
Member #2881
Trader Rating: (7)
haiiro99
Not charging the battery sounds like the regulator/rectifier. Maybe try and replace that?
Old 01-12-2008, 09:11 PM   #9 (permalink)
Member #12315
Pictures: 5
Bikenamspike
ok
Old 01-12-2008, 11:24 PM   #10 (permalink)
MR_Korrupt's Avatar
Member #814
Sportsbike: 1999 TLR 1000
Riding Experience: 11 Years
Life Wasted on TLZone: 1 Month, 3 Weeks, 5 Days and 17:39:34 Hours
MR_Korrupt is waiting for parts...
Send a private message to <!-- google_ad_section_start(weight=ignore) -->MR_Korrupt<!-- google_ad_section_end --> Steve is the prettiest admin
Sounds like the regulator/rectifier. If you have a mate with a TL that can test it on ur bike do that first, or you could try the Zippys charging mod in the frequent mods section as the wiring on these old girls tends to turn the crap.
I plan on leaving this world the same way i came in....... Bloody and screaming.
New TLR- Under construction.
Mods (so far): Yosh full system with 20" CF cans, Power Commander 3USB, PiperCross air filter, Nology leads & profire coils, +positive mod, Rifleman 1/5th throttle insert, GIpro, Scorpio sr500i alarm, Tinted screen, Inline fuel filter mod, Pazzo shortie levers, Brembo 4pad calipers, Brembo radial brake & clutch MCs, AP mini rear brake caliper, Braking wavy rear disc, Pro Bolt Ti rotor bolts, Goodridge brake lines, Hayabusa forks with Traxxion 1kg springs, Carozzeria V star wheels, Ohlins shock, Ohlins steering damper, JMC swingarm, Powder coated black frame, 40tooth rear sprocket w/Speedohealer, Tech-G rearsets, Warp speed rad guards. Vandriver: +1mm swingarm eccentrics, Sprocket cover, Rear caliper bracket, CCC, pressure plate & rear brake res,
To Do list: Put the bike together, Manual fan switch, Charging mod, Headlight Mod, Rizoma Bar end mirrors (maybe)
