TLS Worm Drive - TLZone Forums
Go Back   TLZone Forums > General Forums > What I learned today
What I learned today Post it here to help others from having to learn it the hard way. Please limit it to bike related threads.
Old 06-12-2009, 09:19 AM   #1 (permalink)
Aredubu's Avatar
Member #4263
Sportsbike: A '97 TLS...What Else?
Riding Experience: 24 years
Trader Rating: (31)
Pictures: 15
Life Wasted on TLZone: 1 Month, 3 Weeks, 1 Day and 3:41:43 Hours
Aredubu
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Aredubu<!-- google_ad_section_end --> Steve is the prettiest admin
TLS Worm Drive & Tires
Been reading about the TLS clutch worm drive for year, but never really felt the need to mess with it until this week. I was sitting around and felt like tinkering so I decided to pull the worm drive out and clean it. Good thing I remembered reading about those dang little ball bearings in it! I pull out the shop manual and have at it. The drive itself was just dirty, but the surrounding area had all kinds of gunk, like rocks and old chain o-rings. So, I give it a good cleaning, lube it up with some bearing grease, which was good for keeping those bearings in place during the re-install, make some clutch cable adjustments and all looked good.
Next day, I took my oldest son for a ride round town on the surface streets (he's still a little scared of bikes on the highway) with no issue...cool. Yesterday, I take off to run some errands and I jump on the highway. As I attempt to blast up the on-ramp I feel the pull from the engine and hear it, but damn, I ain't moving like I'm supposed to be moving. I back off the throttle and the clutch engages, but when I jump on it the clutch is slipping like crazy! I know what it is and managed to finish my errands by not being ham-fisted. I get home and adjust the worm drive slightly. Take it back out and flog it to see if I got rid of the slipping. All is well. Thanks for listening.
Oh and always check your tire pressures, even after the mechanic at the dealership just put a new rear tire on your bike! I checked mine a few days ago and both front & rear tires had 20 psi. I know there were no leaks because both tires were exactly at 20 psi. Dumbasses!
(BikeOwners)(Dealers)
Last edited by Aredubu; 06-12-2009 at 09:46 AM.. Reason: Wanted to rant some more!
Old 06-12-2009, 10:26 AM   #2 (permalink)
evl tvn's Avatar
Member #2220
Sportsbike: 2000 TL1000R
Riding Experience: never enough
Trader Rating: (21)
Life Wasted on TLZone: 2 Months, 0 Weeks, 1 Day and 17:36:00 Hours
evl tvn
Send a private message to <!-- google_ad_section_start(weight=ignore) -->evl tvn<!-- google_ad_section_end --> Steve is the prettiest admin
I spray that whole area with brake parts cleaner ones a year blow it out with air gun, pull it all apart, clean and grease also.I found a rubber cup from a hardware store, made a small hole for a stud to go thru and it keeps the bearing clean all year.
Same happen to me just few weeks ago when I installed the PP2CT's, never trust anyone.....
2000 TL1000R B/W,
FULL M4 CERAMIC COATED EXHAUST, PIPERCROSS AIR FILTER, PC II, IVAN'S TRE, MICHELIN PP2, EBC XC ROTORS, EBC HH PADS, ZERO GRAVITY DARK SMOKE DB, BITUBO REAR SHOCK, RACE TECH FRONT FORKS, SCOTTS STEERING DAMPER, HOMEMADE UNDERTRAY WITH TRUNK, CRANKCASE BREATHER SYSTEM, VAN'S CCC, BILLET BRAKE RESERVOIR, SPROCKET COVER, 3/4"TAIL RISERS, SMOKIN FRAME SLIDERS, AIR BOX LID REMOVED, SS BRAKE LINES, SPEEDO HEALER, 17/42 GEARING, EURO HAND SWITCHES, YOSH C/F FRONT FENDER... 22K ON THE CLOCK AND STILL TICKING
drive, worm
