PAIR valve removal shortcut - TLR - TLZone Forums
Go Back   TLZone Forums > General Forums > What I learned today
What I learned today Post it here to help others from having to learn it the hard way. Please limit it to bike related threads.
Old 05-26-2009, 12:18 PM   #1 (permalink)
suprachrgd82's Avatar
Member #17845
Sportsbike: All twins
Riding Experience: 150K+ Mi.
Life Wasted on TLZone: 1 Month, 0 Weeks, 2 Days and 19:35:09 Hours
suprachrgd82 is such a jerk
Send a private message to <!-- google_ad_section_start(weight=ignore) -->suprachrgd82<!-- google_ad_section_end --> Steve is the prettiest admin
I'm anal and wouldn't stand for clamping off the rear tube. But damn, that bottom bolt on the flange, by the head is a b*tch to get to. No way I'm gonna pull the motor to get these things on. So the rear cyl exhaust was pulled, and the damper unbolted (for visibility)...
The top nut came off with relative ease.
And after a night of cussing at the rear tube I just figured, let's find a way to break it off.
So, I started to bend it from the right side, up and down, hoping it would break at the flange by the exhaust port. If it broke, I could access the nut right?
I was shocked to find that it wouldn't break, BUT the flange was bending. Awesome. The flange, from all the flexing, flattened out enough that the nut was then finger tight. Boo-yah!
So off it came, and thanks to Chucks tips of using a magnet/antenna thingy, it was retreived.
Off it went, and then to get the block off plate on...
Dunno if there's any RCers out there, but theres cool sticky tape called servo tape. Double stick the plate to a finger tip with servo-tape to get it on the studs.
Then use the magnet/antenna thingy to place the nuts over the studs, thru the frame side. Gently spin em on with a fingertip.
You do not talk about Fight Club....
2003 TL1000R Y/B - Full M4 system with D&D bolt-ons, HyperPro RSC, Ohlins rear, Revolution Rotors, Danos TRE, K&N, Airbox mod, 195 fan switch ('94 civic), PAIR removed, 41T SuperSprox, LED lights, , Zero Gravity Smoked, Goodridge lines, Pilot Road 2CT, Van's reservoirs, HK Levers, HK Rearsets, HK Chain Adjusters, Bestem Undertail, Bestem Hugger, Hotbodies U/T, Ducati fender eliminator, gap mod
Old 08-26-2009, 01:38 AM   #2 (permalink)
Spyrious's Avatar
Member #18500
Sportsbike: 00' TL1000R
Riding Experience: Rookie
Life Wasted on TLZone: 1 Week, 2 Days and 11:01:45 Hours
Spyrious
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Spyrious<!-- google_ad_section_end --> Steve is the prettiest admin
Good info.I will need it soon.Thanks.
Old 08-27-2009, 05:37 PM   #3 (permalink)
TLR-Billbo's Avatar
Member #1415
Trader Rating: (48)
TLR-Billbo is dreading winter coming
good ideas
luckily I did mine when the engine was out when my frame was powdercoated
*2005 SXR 800*Skat 9/17 140-75 SS Impeller*Blowsion mat kit*Blowsion billet bilge switch*Rule 500GPH bilge*R&D bilge bracket*R&D billet angled reed spacers*V-Force Delta 2 Carbon reeds*R&D exhaust sleeve*Wamiltons scupper*Wamiltons stubby pump cone*fuel fill and pickup mod*-4" hull*-1.5" pole*R&D stealth intake grate*-4" ride plate*ODI grips*R&D Pro-lock filters*Jetworks mixture screws*Blowsion billet engine mount keepers*R&D 6º ignition adv kit*Billet driveshaft coupler*dual-cooling*Wiseco 80.96mm factory Kawi race pistons (true 800cc)*UMI Billet throttle lever*
MySpace and Facebook
Old 09-15-2009, 09:22 AM   #4 (permalink)
MattTheHat's Avatar
Member #18452
Sportsbike: 2003 TL1000R
Riding Experience: 33 years
Trader Rating: (44)
Pictures: 30
Life Wasted on TLZone: 2 Weeks, 2 Days and 17:27:32 Hours
MattTheHat
Send a private message to <!-- google_ad_section_start(weight=ignore) -->MattTheHat<!-- google_ad_section_end --> Steve is the prettiest admin
On mine, I used a regular 1/4" socket, on a swivel and then a 4-5" extension. Routed it through the bottom hole in the left side of the frame. You can watch from above, and a hand crammed beside the shock can give it a little guidance. Really not too hard to remove. Putting it back on was much worse. I'll bet I dropped the nut ten times.
Need some of those magnetic socket inserts, I guess.
-Matt
pair, removal, shortcut, valve
