Hi Everybody,
Well after a hard period of time in life, which has now passed for the time being. Im back building or "putting together a project"
I decided to go down the TLS route this time, just for something different, all TL's are my cuppa tea R or S so either motorcycle didnt bother me.
Well here we go a little bit about the original Bike:
Black TL1000S.
15000 miles.
No Tax or MOT.
Really poor bodywork.
No service history or record for maintenance.
To give an idea of her overall condition!!!!!
Right!! got her home spent a few moments together and then began the "project" as Hot Chocolate said "it started with a kiss" haha
Admittedly she had been sat for what i can gather in a back yard for around 18Months, Not ran and untouched due to a wiring issue which is starter relay directed.
To give an idea of its idle state for around 18months.
I did not spend the time trying to get her running, I dropped the oil on purchase which was crystal clear so i was semi sure it was at the very least a good motor.
Some images of the strip, but also to give a good idea of her condition.
One Engine and one Chassis!!!!
One TLS in parts.
One TLS engine for service and repair!!!
Well after a complete check of the original frame she has taken a bad knock to the headstock area which has created a couple of cracks..................................
But on a lighter note a new frame has been supplied by a invaluable TLZONE member, cant thank enough for the help and time. MEGA!!!!!!!!!!!!!!!!
Old frame with the crack.
Bad Times!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!
New frame with all the transfered nuts and bolts buffed and greased correclty, although this is a picture, I cant stress the amount of work it took to get her looking fresh and also all the weathered trim and nuts and bolts!!!!!!!!!!!!
Well upto now, Yes its been a graft but there is the makings of something very nice indeedy.
Im unsure on improvements and other bits and bats, but its important to me the input of the zone is incorporated in one way or the other so i can only thank you for your help in advance.
MUCHAS GRASSY BUM!!!!!!!!!!!!!!
20Likes
LinkBack URL
About LinkBacks
looking good mate, remember im here when you need a hand mate.
k7 radial front forks and calipers, R powder coated swingarm with steel custom brackets and Honda 900 Hornet rear shock and 1100 lbs spring. R headers welded onto S front down pipe,home made front damper mod, pc111 usb, airbox mod, Art twin outlet oval cans, hydro clutch and Barnett springs,TRE, K&N Filter, gap mod tray,carbon undertray,tiny indys,top yoke conversion to mx bars,R6 throttle tube, Later ecu so no more stumbles at 3000 revs.6 spring clutch fitted with custom black pressure plate and clear clutch cover, cheers sparky,adam,chris and stu for the parts.
