Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 38
Thread: R1 Shock Mod on TL1000S
    Silver Subscriber gaztl1000r's Avatar
    Dec 2003
    nottingham UK
    9,163
    This is whY you're trying to recreate
    Who's fkin happy??.?? not me said snow white.R6 damper gsxr k4/5 forks with gold calipers ,blackshadow discs,soon to be a hid/projector headlight,Harris adjustable rearsets,in need of a Cham steering damper mod,pc2 k&n, much more to come
    Silver Subscriber Paul81272's Avatar
    Mar 2009
    North Wales (UK)
    44
    would stainless steel bolts be suitable or should I use BZP high tensile steel?
    TL1000S, I love it !
    Gold Subscriber Toledo's Avatar
    Jul 2005
    Kent, UK
    10,552
    High tensile
    Mark.
    TLOTM JULY '11
    People I will not deal with: tl1000s/tl1000r Will/2012-krystal or whatever he decides he might/might not call himself.
  4. #14
    Mar 2009
    North Wales (UK)
    44
    is there a "standard set up" I should use as a starting point with the R1 shock?
  5. #15
    Dec 2003
    nottingham UK
    9,163
    Guess work really
    One tip to help.fitting, wind the rebound up to max and compress the damper,it'll let you get it all in place
    Then fit it without the bracket and set rebound about half way,then fit the bracket
  6. #16
    Mar 2009
    North Wales (UK)
    44
    a couple of things, it was going really well, much better/quicker than I had anticipated and then the bolt which holds the subframe to the main frame snapped right in the middle !!! what a bummer, I will have to wait now until I fetch my Dremmel from home to complete. only took me a couple of hours.
    I am assuming that I will wind both comp & rebound to middle then half a turn hard to start with as I am about 15 stone and work from there.
  7. #17
    Mar 2009
    North Wales (UK)
    44
    there doesn't appear to be much "travel" on the damper, only about 2cm (with the rubber wiper/cleaner in place). should I cut away the wiper/cleaner or at least reduce it to increase travel possibilities?
  8. #18
    Dec 2003
    nottingham UK
    9,163
    Yes remove the bump stop
    Or if you want leave a thin slice
  9. #19
    Mar 2009
    North Wales (UK)
    44
    thanks, all advice has been much appreciated
  10. #20
    Mar 2009
    North Wales (UK)
    44
    The finished job, fairly pleased at how it went, thanks again to all those that helped out with advice/tips etc. Thanks guys
