| UK Forum (Including Scotland) A place for the UK blokes to go mad for sizing up their middle legs. Blither on! |
07-04-2009, 01:22 AM
Member #6534
Sportsbike: B/W 02 TLR
Pictures: 7
Life Wasted on TLZone: 2 Weeks, 0 Days and 6:30:14 Hours
tryr
Postcode for Scottish Address
Can somebody from Scotland help me with an address.
Is "Shearer Square ,Dunfermline Fife, Scotland" a legitimate address?
I've left out the number.
Is there a postcode?
Yoshi bolt ons, Chewys angled spacers,Vandriver Adjustable Exhaust Hangers,JSD3A,Pipercross airfilter ,Rifleman's 1/5 throttle mod,5.5 Gixxer Srad 600 rear rim,16 tooth front sprocket,Speedo Healer,Vandriver solid clutch cover with slider,Vandriver return spring and spacer on rear m/c, Vandriver billet rear reservoir,Vandriver sprocket cover,Barnett Clutch Springs,Ohlins shock with internal spacers changed(5mm swapped for 2mm to lengthen shaft 3mm),Vandriver +1 mm Swingarm Eccentrics,Racetech .95 linear springs,gold valves, rebound check spring mod,rebound needle modded,bump stop mod ,arse up 10mm (before eccentrics added)nose dropped extra 3mm for total of 10 mm tube showing,2.5 weight oil in oem steering damper,extra spring on seat latch,99/07 Hayabusa front axle,Rear axle flipped,Hel front brake lines,19mm Nissin Radial master cylinder,Beowulf top radiator guard painted black,K-Factory fork axle sliders,TLRstackers No Cut Sliders.
07-04-2009, 01:38 AM
Member #785
Sportsbike: Tillis, What else?
Riding Experience: A bit more than it was
Life Wasted on TLZone: 1 Month, 3 Weeks, 6 Days and 3:35:28 Hours
tls-moose
Here you go mate - put as much info into here as you can and it should give you what you want
http://postcode.royalmail.com/portal...&gear=postcode
Done: Fat-bar conversion; DNA Handlebar fairing; TLR Clock conversion; Yosh TLR Headers, one-off link pipes & Carbon cans; Relocated oil cooler; Relocated Coolant bottle; Transistor TRE; PCII; +1/-1 sprockets; Hyperpro steering damper & 916 style mount; Maxton Re-Valved forks; Tokico 6 pot callipers; HEL braided hoses; TLR Swing-arm; Bitubo shock; Yellow Box; 98+ Thermo-mod; JarkkoT +/- mod; Airbox mod; K&N air filter; Riflemans 1/5th; Harris carbon mudguard; Carbon Solo Seat Unit; Pyramid undertray; Powder coated wheels; Mini indicators; LSL rearsets; Scotoiler
07-04-2009, 03:41 AM
Member #6534
Pictures: 7
tryr
Tried the link and it can't locate the postcode. This might be what the UK ebay seller was using when he sent me a message saying he had trouble with the address I gave him.I bought a seat cowl for a Scottish mate (Yamaha thunderace owner) but it was local postage only so his mum is going to send it over.
I managed to verify his mums address doing some searching on the internet so it should get there but no postcode which seems odd.
Forgot to mention he text me back with what he thought was the postcode but it is the map reference.
Are all Scotsman like this?
07-04-2009, 05:40 AM
Member #2223
Sportsbike: TL1000R 'O3 reg
Riding Experience: plenty
Life Wasted on TLZone: 3 Days and 1:47:21 Hours
Essex_Andy
KY11 3BD seems to cover most of Shearer Square ,Dunfermline Fife
I just Googled "Shearer Square Dunfermline Fife postcode"
07-05-2009, 02:17 AM
Member #6534
Pictures: 7
tryr
Thanks for the help . I didn't have a clue about the Alphanumeric UK postcode system but now I do.
I'm annoyed the UK person(ebay seller) didn't think to look at the county of Fife for "KY" and then the number of the town such as 11 or 12 which translates to postcode" KY12" for Dumfermline ,Fife.
I found this link very helpful.
http://www.postcode-info.co.uk/ky12-postcode-info.html
