R1 Calipers on gsxr forks - TLZone Forums
Old 07-04-2009, 11:52 PM   #1 (permalink)
nissn1's Avatar
Member #2232
Sportsbike: frankenbike SV1000S /09 sv650n
Trader Rating: (47)
Pictures: 27
Life Wasted on TLZone: 3 Weeks, 4 Days and 4:23:26 Hours
nissn1
Send a private message to <!-- google_ad_section_start(weight=ignore) -->nissn1<!-- google_ad_section_end --> Steve is the prettiest admin
R1 or GSXR radial ,which ones are better I like the bling factor of R1 radial calipers but intereted to know if there are any other advantages/disadvantages over GSXR calipers which i am currently useing thanks
Old 07-05-2009, 02:25 AM   #2 (permalink)
amulmuz's Avatar
Member #6753
Sportsbike: 98 tlr
Riding Experience: 7yrs
Life Wasted on TLZone: 1 Week, 6 Days and 17:02:14 Hours
amulmuz
Send a private message to <!-- google_ad_section_start(weight=ignore) -->amulmuz<!-- google_ad_section_end --> Steve is the prettiest admin
just make sure you use the right size master cylinder. eg the gsxr nissin 19mm is too big
and the brakes feel totally wooden. i think the oem yam brembo is 16mm
should really put something here
Old 07-05-2009, 02:41 AM   #3 (permalink)
nissn1's Avatar
Member #2232
Trader Rating: (47)
Pictures: 27
nissn1
My stock sv master seems to work just fine with twin line set up , but i have to change calipers back to 05 radial + 5mm spacer ,or go to 320 rotors (sv1000 310mm)as i just found out today. I have 08 calipers on 04/05 600 forks , pads are overlapping outside of rotor by 5mm damn I have a set of 05 600 gold calipers but i think i will change out to a larger rotors
Old 07-05-2009, 05:08 AM   #4 (permalink)
amulmuz's Avatar
Member #6753
Sportsbike: 98 tlr
amulmuz
my point about the master cylinder choice is that r1 calipers have smaller pistons than the tokico ones. bummer about your problem. obviously there are so many combo's when matching calipers, disks etc and making sure you get it right.
Old 07-05-2009, 05:26 AM   #5 (permalink)
Life Wasted on TLZone: 3 Months, 2 Weeks, 1 Day and 19:51:09 Hours
Is there room to machine 5mm off the mounting points on the calipers and not foul the mounts on the forks?
Old 07-05-2009, 05:35 AM   #6 (permalink)
TLDV8's Avatar
Member #1349
Sportsbike: DR650 ADV/SM
Trader Rating: (38)
Pictures: 220
Life Wasted on TLZone: 3 Weeks, 4 Days and 18:57:48 Hours
TLDV8
Send a private message to <!-- google_ad_section_start(weight=ignore) -->TLDV8<!-- google_ad_section_end --> Steve is the prettiest admin
2003/2004 GSXR 1000 calipers for the 300mm rotors might work as the mount height is lower than the later calipers.
Steve might be able to measure his calipers.
2008 DR650 Ohlins Shock - Race Tech .46 Springs/Emulators/20W oil - GSXR Muffler & FMF PowerBomb header - Mikuni TM 40 Pumper - Twin Air Airfilter - Pro taper Contour Bars - Acerbis Handguards - Volar Foot pegs - Zumo 550 - Moto-Sport Racks - Andy Strapz Panniers - Wolfman Expedition Rear Bag - Utah Sport Bash Plate - Screens for Bikes Screen - Corbin Seat - Safari 32 litre Fuel Tank - AMP Case Savers - Dunlop D606's.
Road trim.. Procycle SM wheels - Michelin Pilot Road 2's - EBC Rotors - Braided Brake Lines
http://i30.photobucket.com/albums/c345/manurewa/YL8Small-2.jpg
Old 07-05-2009, 05:46 AM   #7 (permalink)
nissn1's Avatar
Member #2232
Trader Rating: (47)
Pictures: 27
nissn1
thats right , i have a set of 04/05 600/750 calipers but they need 5mm spacers with 310 sv rotors. or just go to 300mm without spacers so stil have to swap rotors there!
is there any difference in brake pad size between early model and late model gsxr radial brake pads I would be guessing the pads all have the same contact area ?
i guess thats possible if you had access to such machinery , should be enough thread left for shorter mounting bolts
Old 07-05-2009, 06:02 AM   #8 (permalink)
machine the caliper not the fork , shorter bolt. same thread in fork.
Old 07-05-2009, 06:09 AM   #9 (permalink)
TLDV8's Avatar
Member #1349
Trader Rating: (38)
Pictures: 220
TLDV8
The only difference i thought was the 03/04 1000 caliper being a 4 pad item.
Does the SV have its own 310mm rotor with the old 69mm bore,i thought the only 310mm rotor was the late GSXR item with the totally different bolt pattern and PCD.
The 300mm rotor was the last one with the similar bore and PCD to the TL rotor.
5mm spacers to retain the 310's wouldn't be that bad.?
As Amulmuz says the R1 caliper (27mm/30mm piston) used a 16mm radial,a Brembo 18/19 radial would work nicely with the GSXR calipers (30mm/34mm pistons)
As far as machining you would need to split the caliper so the part line face could be clocked on a angle plate then fly cut.
The problem might be the mount bosses have a flare at the mount face,removing that might negate the radial being rigid.
Old 07-05-2009, 06:23 AM   #10 (permalink)
TLDV8's Avatar
Member #1349
Trader Rating: (38)
Pictures: 220
TLDV8
The mount is fairly deep on the later caliper.
There is nothing complicated about it,just measurements.
Look what happened with forks,the reality is with triples they all bolt on in 5 minutes.
More than likely there will be up to three caliper height differences,a simple combination with spacers will let them work on any rotor set up.
Sadly if i was back home and close to my lathe i could have proved it by having some spacers in the mail.
calipers, forks, gsxr
