R1 Calipers on gsxr forks - Page 2 - TLZone Forums
Old 07-05-2009, 06:28 AM   #11 (permalink)
J-Bone's Avatar
Member #69
Sportsbike: tiller
Riding Experience: some
Trader Rating: (9)
Life Wasted on TLZone: 4 Weeks, 1 Day and 9:34:01 Hours
J-Bone
Send a private message to <!-- google_ad_section_start(weight=ignore) -->J-Bone<!-- google_ad_section_end --> Steve is the prettiest admin
Originally Posted by TLDV8 View Post
The only difference i thought was the 03/04 1000 caliper being a 4 pad item.
Does the SV have its own 310mm rotor with the old 69mm bore,i thought the only 310mm rotor was the late GSXR item with the totally different bolt pattern and PCD.
The 300mm rotor was the last one with the similar bore and PCD to the TL rotor.
5mm spacers to retain the 310's wouldn't be that bad.?
As Amulmuz says the R1 caliper (27mm/30mm piston) used a 16mm radial,a Brembo 18/19 radial would work nicely with the GSXR calipers (30mm/34mm pistons)
As far as machining you would need to split the caliper so the part line face could be clocked on a angle plate then fly cut.
The problem might be the mount bosses have a flare at the mount face,removing that might negate the radial being rigid.
Would a Brembo 19x18 work with the R1 caliper (27mm/30mm piston)? Better/worse/different than with the GSXR caliper (30mm/34mm pistons)?
Why and how?
I have a Brembo 19x18 and Im planning to go the GSXR forks w/ R1 calipers and TL spec wheel&rotors (320mm). Sound good or bad? Will a GSXR caliper work better?
Done:
-==- Full Akra Evo Ti w/ custom hangers -==- CZ Stage2 wheels -==- Semi-floating rotors by Speedking -==- Brembo 19x18 m/c -==- Galfer HH's -==- Galfer wavy rear -==- Bitubo shock -==- Rosmoto adj. rearsets -==- ExtremeTech damper -==- PCIII USB -==- Van's rear brake res. -==- Van's sprocket cover -==- Joe V mod -==- K&N filter -==- Galfer lines -==- 520 conv. @ 16/40 -==- Speedohealer -==- No-cut sliders -==- GSXR K2 rear caliper -==- Pairvalve mod -==- GiPro w/ ATRE -==- BRG 1/5 throttle -==- Avia Comp. C/F mirrors -==- C/F fender -==- Pyramid C/F hugger -==- GCC C/F tankprotector -==- FSMD undertail -==- LP speedscreen -==- Flush signals -==- Subframe mod. -==- GAP mod. -==- Quick release tank & seat -==- Preload adjusters -==-
To come:
-==- GSXR750K4 forks -==- R1 radial calipers -==- Woodcraft Clip-on's -==- Pro-Grips -==- Van's CCC -==- Van's PP -==- Van's +1mm eccentrics -==- Barnett clutch springs -==- TWM gas cap -==-
Old 07-05-2009, 06:35 AM   #12 (permalink)
TLDV8's Avatar
Member #1349
Sportsbike: DR650 ADV/SM
Trader Rating: (38)
Pictures: 220
Life Wasted on TLZone: 3 Weeks, 4 Days and 18:57:48 Hours
TLDV8
Send a private message to <!-- google_ad_section_start(weight=ignore) -->TLDV8<!-- google_ad_section_end --> Steve is the prettiest admin
Why and how?
I never got to find out before putting my bikes into storage.
I could have tested 310mm/320mm rotors with R1/GSXR calipers with both the 16mm and 18/19 Brembo.
It will be old news by the time i get back to it.
Who has run a 18/19 Brembo with stock TLS calipers because they to are 27mm/30mm pistons.
2008 DR650 Ohlins Shock - Race Tech .46 Springs/Emulators/20W oil - GSXR Muffler & FMF PowerBomb header - Mikuni TM 40 Pumper - Twin Air Airfilter - Pro taper Contour Bars - Acerbis Handguards - Volar Foot pegs - Zumo 550 - Moto-Sport Racks - Andy Strapz Panniers - Wolfman Expedition Rear Bag - Utah Sport Bash Plate - Screens for Bikes Screen - Corbin Seat - Safari 32 litre Fuel Tank - AMP Case Savers - Dunlop D606's.
Road trim.. Procycle SM wheels - Michelin Pilot Road 2's - EBC Rotors - Braided Brake Lines
http://i30.photobucket.com/albums/c345/manurewa/YL8Small-2.jpg
Old 07-05-2009, 10:16 PM   #13 (permalink)
nissn1's Avatar
Member #2232
Sportsbike: frankenbike SV1000S /09 sv650n
Trader Rating: (47)
Pictures: 27
Life Wasted on TLZone: 3 Weeks, 4 Days and 4:23:26 Hours
nissn1
Send a private message to <!-- google_ad_section_start(weight=ignore) -->nissn1<!-- google_ad_section_end --> Steve is the prettiest admin
yes the sv rotors are 69mm center, same bolt pattern as tl/busa
Old 07-06-2009, 12:26 AM   #14 (permalink)
Sam Sam is online now
Trader Rating: (104)
I have a set of the later calipers that have had 5mm machined off the mounting bosses no problem
Like Les says, fit the shorter boss calipers from the k3/4's and you will be ok.
I've added some extra lines to my fork chart to help with swapping calipers between models
You can work out what spacers are required now by adding the caliper face measurements from whatever combination you are using and comparing that total to what diameter discs you are using, the difference is the caliper spacer thickness, also you can tell from lower down the chart if the should ideally be plain or shouldered on one or two sides
btw the R1 Caliper measurement is a best guess from nissn1 saying he needed 5mm spacers for 03/04 GSXR1000 bottoms, hopefully somebody can verify this.
Old 07-06-2009, 09:09 AM   #15 (permalink)
TLOTM Sept. '08
D'Ecosse's Avatar
Member #12967
Sportsbike: TLS; Daytona; SV650S
Trader Rating: (6)
Life Wasted on TLZone: 3 Months, 2 Weeks, 2 Days and 19:37:40 Hours
D'Ecosse
Send a private message to <!-- google_ad_section_start(weight=ignore) -->D'Ecosse<!-- google_ad_section_end --> Steve is the prettiest admin
...The only difference i thought was the 03/04 1000 caliper being a 4 pad item....
Only the 03 1000 had the 4 pads - the 04 1000 looks similar outwardly, but had gone to 2 pads.
.... Does the SV have its own 310mm rotor with the old 69mm bore,i thought the only 310mm rotor was the late GSXR item with the totally different bolt pattern and PCD....
The SV1K rotors are indeed 310mm with the 69mm bore and will be direct fit on any GSXR 01-04 wheel or also the TL/Hayabusa wheels - unlike the GSXR 310mm rotor which will not fit the TL (or earlier GSXR) wheels, but only 05+1000 or 06+ 600/750 wheels.
Suzuki TL1000S..........Suzuki SV650S..........Triumph Daytona
<a href=http://i289.photobucket.com/albums/ll224/decosse01/Misc/Triple_Threat.jpg target=_blank>http://i289.photobucket.com/albums/l...ple_Threat.jpg</a>
Old 07-06-2009, 09:35 PM   #16 (permalink)
TLDV8's Avatar
Member #1349
Trader Rating: (38)
Pictures: 220
TLDV8
Interesting.
You need to factor in the 08 Hayabusa axle to any late GSXR fork in TL triple mods.
Old 07-06-2009, 11:43 PM   #17 (permalink)
Arghh crap. Hey Sam, where are those calipers I bought for 310mm rotors before I found out the later GSXR's changed the PCD?
Old 07-07-2009, 12:14 AM   #18 (permalink)
Still sealed in a box full of Australian Air......too good to use
calipers, forks, gsxr
