06-17-2009, 06:27 AM
#21 (permalink)
Member #15268
Sportsbike: TL1000S, NC24, GS500E
Riding Experience: First rode a bike in 1990
Life Wasted on TLZone: 4 Days and 19:07:04 Hours
Spoonman
finished his masters and
is starting his Ph.D.
..the chain adjuster broke??
as in the one at the end of the swingarm on each side? how the hell does that break? it's a sodding bolt pushing on the slide blocks for the rear axle.
'98 TL1000S - Full M4 s/s, airbox mod, K&N, Charge mod, ground mod, gap mod, , PCII, TLR battery box, GSXR1000K5 complete front end swap, Bitubo rear shock, c/f mudguard, c/f hugger, GSXR1000K4 mirrors, Steibel Nautilus, headlight relay, Corbin seat, LED tail light.
to do: 6-spring clutch, pro-oiler, trumpets for the TB's, more dyno time.
06-17-2009, 06:43 AM
#22 (permalink)
Member #4340
Riding Experience: 40 years
Life Wasted on TLZone: 2 Weeks, 0 Days and 1:19:18 Hours
cyclecamper
Exactly. What was the real first cause of the problem? Did they forget to tighten the axle?
06-17-2009, 07:29 AM
#23 (permalink)
Member #1415
TLR-Billbo
is dreading winter coming
you lucked out! I had my chain slider come off @~140mph, luckily it shot out and flew in the air up over my buddies head!
* 2005 SXR 800*Skat 9/17 140-75 SS Impeller*Blowsion mat kit*Blowsion billet bilge switch*Rule 500GPH bilge*R&D bilge bracket*R&D billet angled reed spacers*V-Force Delta 2 Carbon reeds*R&D exhaust sleeve*Wamiltons scupper*Wamiltons stubby pump cone*fuel fill and pickup mod*-4" hull*-1.5" pole*R&D stealth intake grate*-4" ride plate*ODI grips*R&D Pro-lock filters*Jetworks mixture screws*Blowsion billet engine mount keepers*R&D 6º ignition adv kit*Billet driveshaft coupler*dual-cooling*Wiseco 80.96mm factory Kawi race pistons (true 800cc)*UMI Billet throttle lever*
MySpace and Facebook
Originally Posted by Shrek
06-17-2009, 07:51 AM
#24 (permalink)
Member #86
Sportsbike: '97 TLS
Life Wasted on TLZone: 4 Days and 20:27:31 Hours
colorado_mat
As said by others, if the rear wheel had been off for some reason (new tire, etc.), one possibility is that the shop didn't properly torque the axle and/or the adjustment bolt/nut. The chain slider itself is probably pretty unlikely to just break on its own -- more likely that it broke when the chain slacked and bunched up.
A tech who worked at a dealership where I once worked had a bike come back after he 'torqued' the rear axle with an impact. Tough to be accurate doing work like this. As the customer was riding, the rear axle slid forward, chain slacked and rammed into the engine case. Damn lucky the guy was able to slide to a stop. I didn't work there much longer -- I took the time to do things right and as a result didn't make enough money to be worthwhile for me, whereas customers paid a great deal for even simple work.
Also, you questioned earlier in the post regarding if something in the clutch could cause a lockup -- absolutely.
You might want to inspect what you can before riding again even after the shop 'completes' the work.
Ride safe.
06-17-2009, 07:54 AM
#25 (permalink)
Member #6290
Sportsbike: 2008 DRZ SM / 2001 TLR
Riding Experience: 30 years
Life Wasted on TLZone: 2 Weeks, 0 Days and 2:52:48 Hours
Foster
Yep, I was going to guess chain buffer.
I replaced mine a couple of years ago as a just in case.
There have been a few that that has happened to in the past.
TlBillbo I think it was your thread that got me looking at mine.
It was one of those 30 dollar deals that was well spent.
06-17-2009, 09:59 AM
#26 (permalink)
Member #16539
Sportsbike: 2003 tl1000r
Pictures: 11
Life Wasted on TLZone: 1 Week, 3 Days and 7:39:30 Hours
rgraves
since i just bought the bike i guess i should have gone through it more closly. i would guess the previous owner is more the cause of the troubles i have had with the bike. the tech i use has a great reputation and is very reasonable on his rates. i did however order a hard copy of the shop manuel and will from here
on take a more active roll in the maintainance of my bike.
06-20-2009, 06:37 AM
#27 (permalink)
Member #16539
Pictures: 11
rgraves
sorry everyone my terminology was off. it was not the chain adjuster that broke it was the chain buffer. a twenty dollar piece caused all the havoc. lets hope she is finally right so i can get some riding time on her. got my manuel in the mail yesterday. so after i pick her up and take her for a spin. i will go through the manuel and start identifiing the parts and start building the confidence to start doing most of my own work. thanks guys!
06-20-2009, 07:00 AM
#28 (permalink)
Member #10892
Sportsbike: '97 TLS '99 YZ125
Riding Experience: a few
Life Wasted on TLZone: 2 Weeks, 1 Day and 5:28:20 Hours
EDS_TLS
I know the TL pretty well and I'm somewhat local. Let me know if you ever need help
Eric
06-20-2009, 08:03 AM
#29 (permalink)
Life Wasted on TLZone: 1 Week, 5 Days and 3:48:31 Hours
ahhhh, CHAIN BUFFER.... now.... that at least makes some sense. Glad the damage was kept to a minimum.
Scorpio SE-i500 system,TLR MOTOR, pc2,yosh full system w/titanium cans ,(thanks 00tiller) k+N filter, UFO tail light kit-sweet! Corbin seat,Heli Bars, Throttle miester, six pot tlr caliper system, dble bubble screen,Galfer ss brake lines front&rear,tl tank protector,Bitubo rear shock-thanks Origin8tor!,clear clutch cover, CRG Levers,clear tailight lens-new paint, front end reworked by Aftershocks, fresh Powdercoated rims and front Wave rotors via TODD at Cal sportbike,as well as a SPEEDO HEALER from him,  ,fan mod-thanks et79,gpi gear indicator w/ATRE-thanks again cal sportbike. MY CUSTOM R/R WIRING HARNESS TO GET CHARGING SYSTEM UP TO PAR! check frequent mod section out!!
