Throttle Body Syncronizer - TLZone Forums
Old 03-24-2009, 12:41 PM   #1 (permalink)
king4477's Avatar
Member #10873
Sportsbike: 98 TLR
Trader Rating: (6)
Life Wasted on TLZone: 1 Week, 2 Days and 1:36:25 Hours
king4477
Send a private message to <!-- google_ad_section_start(weight=ignore) -->king4477<!-- google_ad_section_end --> Steve is the prettiest admin
Anyone have a recommendation on which Carb Sync tool to get to do sync my TBs? I'd love to spend $100 on a MotionPro or a CarbTune but I just cant justify spending that right now.
I was also looking at these
http://cgi.ebay.com/ebaymotors/Carbu...motiveQ5fTools
but they look sort of cheap. Any happy middle ground?
Old 03-24-2009, 12:44 PM   #2 (permalink)
optimus41's Avatar
Member #15658
Sportsbike: 97 TLS
Life Wasted on TLZone: 1 Week, 0 Days and 1:11:05 Hours
optimus41 running out of monies
Send a private message to <!-- google_ad_section_start(weight=ignore) -->optimus41<!-- google_ad_section_end --> Steve is the prettiest admin
im interested too
Old 03-24-2009, 01:24 PM   #3 (permalink)
Life Wasted on TLZone: 3 Months, 1 Week, 6 Days and 1:24:29 Hours
You can make your own. Do a search and you'll find several threads on teh topic. Then you can save your bucks until you can get a Carbtune, a device I highly recommend.
Old 03-24-2009, 01:58 PM   #4 (permalink)
king4477's Avatar
Member #10873
Sportsbike: 98 TLR
Trader Rating: (6)
king4477
Yeah I've been looking through old posts at the home made ones, but I dont trust myself that much
I did see this
which looks promising. Does it matter where you take the vacuum reading: on the designated spot on the left side of the throttle body like the manual tells you to or with this intake cap device dealy?
Old 03-24-2009, 08:48 PM   #5 (permalink)
98ss's Avatar
Member #9366
Sportsbike: 02 TL1000R
Riding Experience: 3 years
Life Wasted on TLZone: 2 Weeks, 1 Day and 7:21:59 Hours
98ss
Send a private message to <!-- google_ad_section_start(weight=ignore) -->98ss<!-- google_ad_section_end --> Steve is the prettiest admin
If you have a vacuum guage, then you don't need one. You can take one reading at a time. Move from one TB to the other and adjust as necessary. It may take an extra 15 minutes. Basically just get each to read the same amount.
Mods: Joe V air box, Fabbri DB windscreen, Ohlins steering damper, Plus Mod, Ground Mod, Power Commander III USB, Yoshi Cans, Barnett Clutch Springs, Iridium Plugs, Clutch Pushrod SV seal, Ghetto rear turnsignals, Bitubo rear Shock, M4 Full super thumper exhuast, Manual fan switch, Supersprox Rear 41T w/ blue EK chain.
Future Mods: TRE, No Cut sliders-on order, Vandriver rearsets, Galfer lines clutch and brakes with HH pads, Arrow Bar ends.
Old 03-24-2009, 10:09 PM   #6 (permalink)
motorbike's Avatar
Member #16853
Sportsbike: TL1000R 1999
Riding Experience: 16 j
Pictures: 2
Life Wasted on TLZone: 3 Days and 7:11:39 Hours
motorbike
Send a private message to <!-- google_ad_section_start(weight=ignore) -->motorbike<!-- google_ad_section_end --> Steve is the prettiest admin
that gauges will work i use the same to do mine
TLR1000R MAN
Old 03-24-2009, 11:38 PM   #7 (permalink)
TLJimmy's Avatar
Member #14541
Sportsbike: 3/97 TL1000S
Riding Experience: 24yr+time off 4 bein bad
Trader Rating: (8)
Life Wasted on TLZone: 1 Month, 0 Weeks, 5 Days and 11:44:50 Hours
TLJimmy Loves Boobies and Bikes
Send a private message to <!-- google_ad_section_start(weight=ignore) -->TLJimmy<!-- google_ad_section_end --> Steve is the prettiest admin
Make your own. $5bucks and more accurate than the ballbearing jobbies.
Search sync tool...here you go, did it for you
http://i104.photobucket.com/albums/m...2/IMG_1053.jpg
Ride it like you stole it.
From Randy's pages:
...Newbie riders should simply skip the TL and go straight to the morgue.
Mods done: 2 Bros mufflers;homemade TRE;Airbox mod;'97 temp sensor mod;Iridium plugs;TLR bellmouths;OEM-style smoked screen;HH sintered pads front and rear;Metal Gear rotors with gold carriers;removed OEM mirrors and mounts;bar-end mirror with cut down stock weight as spacer; chopped rear fender; DID gold x-ring heavy duty chain;2 up on rear sprocket;damper mount mod for easy tank lifting;forks up-in-the-triples 7.5mm;Riflemans clear clutch cover and 1/5 throttle insert;Barnett clutch springs;Mini CF look indicators front; mini chrome LED's rear with resister;2.5wt oil in stock damper;PC II;Bitubo rear shock;Forks - Race Tech internals with 1kg/mm springs and Gold valves;braided front brake line;billet sprocket cover;charging mod;plus mod;
To do:TLR MC;black; paintTLR swingarm;chequer plate undertail;6 pot brakes;inline fuel filter;hotgrips
Old 03-25-2009, 01:19 PM   #8 (permalink)
Badrhino's Avatar
Member #13544
Sportsbike: 1999 Suzuki TL1000S, 1980 KZ1000
Riding Experience: 30 years
Pictures: 11
Life Wasted on TLZone: 1 Week, 2 Days and 1:20:01 Hours
Badrhino
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Badrhino<!-- google_ad_section_end --> Steve is the prettiest admin
I still need to do this.
Remember, today is the tomorrow you worried about yesterday. -Dale Carnegie
1999 TL1000S, Akropovic Full Titanium Exhaust, PC 2,K&N, JSD TRE, 520 RK Gold Chain, Down 1 Up 2 Vortex Sprockets, Riflemans Clear Clutch Cover, 6 Pots, Steel Braided Brake Lines, Double Bubble,Throttlemiester Bar Ends, Corbin Seat, Lower Cowling, Tank Bra, Fender Eliminator
Working on: Airbox Mod
Old 03-25-2009, 02:00 PM   #9 (permalink)
king4477's Avatar
Member #10873
Sportsbike: 98 TLR
Trader Rating: (6)
king4477
That video in the archieve is very good and detailed, but it's a half-hour! Seems like there's probably 5 minutes of info in there. I googled "How to sync throttle bodies" and immediately came up with a dozen step-by-step how to's.
body, syncronizer, throttle
