Water wetter colant additive???? - TLZone Forums
Old 10-13-2008, 09:56 AM   #1 (permalink)
dirtybird750's Avatar
Member #2250
Sportsbike: 98 TLR with lil BLING,2001 GSX-R 750 - chrome, 1987 FLH Hardley Ableson, 1987 Honda CR250
Riding Experience: 15+
Life Wasted on TLZone: 3 Days and 0:02:48 Hours
dirtybird750
Send a private message to <!-- google_ad_section_start(weight=ignore) -->dirtybird750<!-- google_ad_section_end --> Steve is the prettiest admin
Has any one used this in there TL? I'am talking about water wetter the red stuff in PEP Boys That says that will make the motor tem 10 degrees lower. Dose it work or is it B/S and will F your bike up.
Old 10-13-2008, 10:01 AM   #2 (permalink)
NYCSTRIPES's Avatar
Member #2807
Sportsbike: 2003 TL-1000R, 2006 Triumph Daytona 675, 1998 Valkyrie
Riding Experience: 20 years
Trader Rating: (27)
Life Wasted on TLZone: 6 Days and 22:05:35 Hours
NYCSTRIPES
Send a private message to <!-- google_ad_section_start(weight=ignore) -->NYCSTRIPES<!-- google_ad_section_end --> Steve is the prettiest admin
It works very well, geared more for track riders since it is glycol free and easier to clean up from the track in the event of a coolant leak at a crash site.. If you ride on the street, just stay with standard antifreeze or look into Engine Ice. Engine Ice cools as well as Water Wetter but can be left in over the winter. Engine Ice is just pretty expensive going for over $30 per gallon. If you don't do any trck days stick with standard anti-freeze.
Unfortunately Water Wetter is not capable of working through the winter months, it will freeze in the motor if the bike is left someplace without heat. Remember to drain your cooling system before the temperature drops.
Ken
2003 TL1000R Track Bike#489
2006 Triumph D675 track bike #489
1998 Valkyrie for long rides
www.redflagfund.org
Old 10-13-2008, 10:05 AM   #3 (permalink)
i8marcus's Avatar
Member #9967
Sportsbike: 98 TLR & 02 YZ250
Riding Experience: 12+ Years
Life Wasted on TLZone: 2 Weeks, 3 Days and 11:19:44 Hours
i8marcus
Send a private message to <!-- google_ad_section_start(weight=ignore) -->i8marcus<!-- google_ad_section_end --> Steve is the prettiest admin
I use water wetter also and have had good results... I use it all year as I live in California and it never is cold enough to require antifreeze here. As mentioned above if you live anywhere it gets cold don't forget to change back to normal anti-freeze during the winter.
1998 TL1000R
Yoshimura RS-3 Exhaust, Forks reworked by Racetech, RaceTech valved Showa Shock/Eibach Superbike Spring, Ivan's TRE, Brembo HP Rotors, Brembo 19x18 Clutch M/C, Brembo 19x18 Brake M/C, EBC HH Pads, Galfer SS Brake & Clutch Lines, Hyperpro RSC Damper, CFM/Woodcraft Rearsets, CFM/Woodcraft Clip-on's, Stealth Tri Metal Sprocket 17/42, DID Chain, Michelin Pilot Powers, BMC Air Filter, Zero Gravity Windscreen, GSXR Race Tail.
"Brake later and open the throttle before normal" -Valentino Rossi
Old 10-13-2008, 10:12 AM   #4 (permalink)
Member #2250
dirtybird750
I just read the boddle and it said that you can run with a antifreeze mix or stright water. Will it make a dif in cooling mixed with a 50/50 antifreeze?
Old 10-13-2008, 12:39 PM   #5 (permalink)
Life Wasted on TLZone: 3 Months, 1 Week, 6 Days and 0:23:45 Hours
Yep, I run it in everything I own with a 50/50 water anti-freeze mix. It does lower operating temps a bit if you can believe the gauges.
Old 10-22-2008, 09:51 AM   #6 (permalink)
Member #14242
Sportsbike: 2000 TL1000R
Life Wasted on TLZone: 1:35:50 Hours
thacure3
Send a private message to <!-- google_ad_section_start(weight=ignore) -->thacure3<!-- google_ad_section_end --> Steve is the prettiest admin
what typ of coolant is best for my tl1000r?
Old 10-22-2008, 11:08 AM   #7 (permalink)
wsmc831's Avatar
Member #368
Sportsbike: 1997 TLS 2002 KTM 300MXC
Riding Experience: First bike, 1983
Life Wasted on TLZone: 1 Week, 0 Days and 1:34:03 Hours
wsmc831
Send a private message to <!-- google_ad_section_start(weight=ignore) -->wsmc831<!-- google_ad_section_end --> Steve is the prettiest admin
new
1997 TLS - the subtle green one. Yosh full system, custom high mount. PcII, Sharkskinz TLR one piece race tail with anti draft undertail, Zero gravity double, Pro-tek rearsets, Hyperpro 916 style damper, corbin seat, Vortex triple clamp, airtech hugger, Penske/Lindeman rear shock and linkage, Lindeman superbike fork valve job, Marchesini 10 spoke Black, Gsxr 750 6 piston calipers and larger m/c, SS brake lines front and rear, Braking Wave Rotors front, milled gsxr rotor rear, billet preload adjusters, airbox reworked, Graves clutch cover, gsxr 1000 rear caliper, Stealth tri metal rear sprocket, Rk 520 chain, sprocket specialists front, KN air filter, Black/gold Pazzo levers, Vortex black gas cap, Ti bolts, ceramic coated headers, 05 1k clip ons, 4 lb battery.
January 2009, the end of an error.
Old 10-22-2008, 12:44 PM   #8 (permalink)
Member #15419
Life Wasted on TLZone: 3 Days and 11:21:41 Hours
Ripp'n
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Ripp'n<!-- google_ad_section_end --> Steve is the prettiest admin
OK OK, may I interate?
It gets HOT in the summer here in E. WA... summer can reach 105F. I was on the hunt for all the tricks I could find... water wetter type stuff. I found at Wal-Mart, A BALKAMP brand product called "RV COOLING SYSTEM ENHANCER"... 1qt red and black can. It does the surface tension reducer gig that WW is known for... about 6.75$ A QT!!!!!!!!!!!!!!!!!!!!!!! Prolly at Nappa ( local auto parts)too. We have alot of street rods here too and they SWEAR BY "ENGINE ICE"... traffic, lumpy small blocks, small radiators, and A/C...no wonder they NEED it !!!!!!!!!!!!!!!!!!!!!!!
I have a manual fan on my 00 12r... it shure HELPS to get that fan on, before I come off the slab... STAY COOL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Free and clean, Ripp'n
Old 10-22-2008, 12:50 PM   #9 (permalink)
wsmc831's Avatar
Member #368
wsmc831
I've used it in various applications in the past, mostly due to track organizations requiring non glycol. Never noticed much of a difference in any streetbike. Many people have installed a manual fan switch, but it's much more common on TLR's than S's. I've seen up to 113 degrees external temp and never had the TL overheat, fans just come on a bit sooner.
Old 10-22-2008, 01:15 PM   #10 (permalink)
N2wheelies's Avatar
Member #301
Sportsbike: 97 tls, 05 sv650, 97wr250
Riding Experience: 24 yrs
Trader Rating: (105)
Life Wasted on TLZone: 3 Weeks, 0 Days and 1:48:53 Hours
N2wheelies
Send a private message to <!-- google_ad_section_start(weight=ignore) --><b>N2wheelies</b><!-- google_ad_section_end --> Steve is the prettiest admin
works great. +1
TLZone Forums Staff - Resident Doctor of Drag
additive????, colant, water, wetter
