Engine cutting out - TLZone Forums
This box pays the bills.
Old 08-27-2008, 12:30 PM   #1 (permalink)
Member #15465
Life Wasted on TLZone: 3:04:14 Hours
bryan748
Send a private message to <!-- google_ad_section_start(weight=ignore) -->bryan748<!-- google_ad_section_end --> Steve is the prettiest admin
Engine cutting out
I posted a thread yesterday, with my TLS cutting out after I ran out of fuel.
I have replaced the fuel filter and pump (friend had a spare) but this has not helped.
The bikes engine cuts out completely and will not re-start, until left for a while, then start again no problem, this is completely sporadic, rode 30 miles today, then cut out three times on the way home.
I suspect an electrical problem, perhaps a broken / shorting wire or corroded terminal.
Does any one have any thoughts where to start ?
When the bike cuts out, everything else works fine electrically, bike won't start with side stand up or down and the time it needs before re-starting is completely random.
I am at a complete loss and it's driving me nuts!!!!
Old 08-27-2008, 01:35 PM   #2 (permalink)
Posh Johnny's Avatar
Member #5574
Sportsbike: Boo hoo don't rub it in!!!
Riding Experience: 6 points in Bala
Trader Rating: (13)
Life Wasted on TLZone: 1 Week, 6 Days and 7:54:15 Hours
Posh Johnny
Send a private message to <!-- google_ad_section_start(weight=ignore) --><b>Posh Johnny</b><!-- google_ad_section_end --> Steve is the prettiest admin
Check out the tip over sensor or the side stand electrics
Old 08-27-2008, 01:57 PM   #3 (permalink)
TLOTM Oct'08
alex4danatls's Avatar
Member #10053
Sportsbike: 97 TLS
Riding Experience: Quite a few years
Trader Rating: (6)
Pictures: 34
Life Wasted on TLZone: 3 Weeks, 0 Days and 4:31:20 Hours
alex4danatls is thinking of next mod
Send a private message to <!-- google_ad_section_start(weight=ignore) -->alex4danatls<!-- google_ad_section_end --> Steve is the prettiest admin
Try speaking to Ben Curtis he has the same problem everytime he stops at traffic lights his cuts out. I believe he knows what is causing it but has yet to sort it pm him im sure he might be able to point you in the right direction if you have the same problem.
Mods so far:
Maxton rear shock, ohlins steering damper, harris brace, TLR forks, wavey discs, goodridge front brake lines, red calipers, supersprox rear sprocket, 5/8 master cylinder, modded airbox with K&N, full M4 system, pc2, LSL rearsets, polished rims, barnett springs, clear led rear light, R&G crash protectors, carbon rear hugger, Airblade double bubble screen, SV1000 belly pan, tinycator indicators, glpro gear indicator, stomp grips, Litetech carbon mirrors, lowered seat, 1/5 throttle insert, clear clutch cover, Black pressure plate with black retainers and ss bolts, headlight mod using projectors with white Halo's and 6000k HID, red leds in engine bay and undertray white leds in air intake tubes.
Old 08-27-2008, 10:01 PM   #4 (permalink)
Sportsbike: TLess, GSXR1000 K3
Trader Rating: (42)
Pictures: 61
Life Wasted on TLZone: 2 Months, 0 Weeks, 1 Day and 19:36:38 Hours
Steve TLS looks pretty in pink
It it doesn't even crank, and the rest of the electrics appear to work I'd be checking the side stand switch. (And then side stand relay, bar kill switch etc). Does it say 'CHEC' in the dash when it cuts out or wont start?
If it cranks but wont fire, does the dash flash up 'FI'? If so put it into dealer mode and find out what the code is. (There's been two recently that have had their Tip over sensors installed up side down). Dealer Mode >>> http://wotid.com/tls/content/view/54/60/
-My TLS pages- -My GSXR pages- -My Dyno pages- -My Blog-
Old 08-27-2008, 10:12 PM   #5 (permalink)
CMonkee's Avatar
Member #5107
Riding Experience: Intermediate (25 years)
Life Wasted on TLZone: 1 Week, 4 Days and 6:19:20 Hours
CMonkee
Send a private message to <!-- google_ad_section_start(weight=ignore) -->CMonkee<!-- google_ad_section_end --> Steve is the prettiest admin
Try wiggling the starter relay harness with the key in the on position and in neutral. Does it click? I.E. loose connection. Clean and die-electric grease it. I permanently modded mine. It's one of those dodgy TL things.
Good luck.
C
A monkey a day keeps the bananas away!
cutting, engine
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
The TLZone Blog:
