You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. If you are already a member, but have forgotten your password, you can have it sent to your email address by using this form. |
LinkBack | Thread Tools | Display Modes |
#11 (permalink) |
![]() Member #103
Sportsbike: TLess, GSXR1000 K3
Trader Rating: (42)
Pictures: 61
Life Wasted on TLZone: 2 Months, 0 Weeks, 1 Day and 19:36:38 Hours
looks pretty in pink
Why do you say that?
Even on the original ECU, a gear position sensor was fitted and wired to the ECU so it knew what gear the engine was in. They went to that trouble and never used it until they recalled the ECU's and fitted later generation ones. ![]()
Steve "I spent most of my money on Scotch, women and cigarettes. The rest I just wasted" TLZone Forums Staff - Resident Antipodean Questions about the Forums? Click Here Help Support TLZone: Subscribe -TLzone- -Ninja6zone- -RSVzone.com- -TuonoZone.com- -My TLS pages- -My GSXR pages- -My Dyno pages- -My Blog- |
#12 (permalink) |
Member #7563
Sportsbike: TL-r, Bandit 6
Riding Experience: 3 years
Life Wasted on TLZone: 1 Week, 2 Days and 17:43:10 Hours
Loki-TLR
So slipping clutch, and krankcase breather were no official recall jobs?
..Seducing TL rumble playing my mind once again.. |
#13 (permalink) |
![]() Member #103
Trader Rating: (42)
Pictures: 61
Nope, not for the coolant sensor in the radiator either.
For '98 they changed the breather, coolant sensor, ECU etc, then from 99 onwards they slipped in a TLR 6 spring clutch. There were other changes too. Output shaft bearing width, crank oiling, oil pump, heads etc, etc.
#14 (permalink) |
Member #7804
Sportsbike: 1997 TLS, 2000 TLR
Riding Experience: 20 years or so
Life Wasted on TLZone: 1 Week, 3 Days and 12:24:37 Hours
abn
Doesn't the manual state that that is for ram air compensation in higher gears (higher gears=>higher speed=>ram air compensation)?
#15 (permalink) |
Member #5251
Sportsbike: tl1000sv,cb1100r
Riding Experience: definately
Life Wasted on TLZone: 6 Days and 11:17:02 Hours
jagboy1
i dyno'd both ecu's...one straight after ther other.....no noticable difference on power.....
TL1000SV(97),tlr motor with 1040 bore kit,,radiused inlets,flowed heads,modded airbox with tlr bell mouths,k & n filter,lightened flywheel,,57mm downpipes with matching one off cams, + and ground mods.pc3 with custom map,six pots with braided hoses,05 gold on gold busa forks, ohlins rear shock,tlr swingarm,metzeler racetecs(rear 190/55/17)two teeth up on rear sprocket.
#16 (permalink) |
Member #12253
Sportsbike: tl1000s 1997
Life Wasted on TLZone: 7:54:04 Hours
tlh
is always off-line
with the ecu the thermostat is replaced also. this was 1 recall.
Frame only in case of cracks. Mine is still a 1997 one. Other parts replaced, under warranty, but not as a recall. - exhaust mufflers due to cracking - clutch cover due to leaking - clutch itself: slipping. still a 5 bolt
TLs 1997 Black, Dymag wheels, Ohlins rear, revalved front, Matris M2 steering damper, Braking waves front and rear, braided hoses, Metezler Racetecs, Pazzo´s, K&N, Yoshimura Titanium bolt ons, TechG rearset |
#17 (permalink) |
Gold-pressed Latinum Subscriber
Member #14928
Sportsbike: 1997 TL1000S
Riding Experience: All my life
Life Wasted on TLZone: 5 Days and 4:01:34 Hours
merlin72875
Okay so my TLS says 1/97 on the manufacture date.. how do I go about checking if I can get recall stuff taken care of? will they still do it?
Thanks!!
-- '97 Suzuki TL1000S |
#18 (permalink) |
![]() Member #103
Trader Rating: (42)
Pictures: 61
Normally there's a sticker on the side of the frame to let you know. I doubt you'll get any joy from Suzuki 11 & a half years later. They would have sent a letter to the person they had on record as having that VIN, if they didn't take it in then SOL I think.
#19 (permalink) | |
Member #14541
Sportsbike: '97 TL1000Sv
Riding Experience: 22yr+time off 4 bein bad
Life Wasted on TLZone: 2 Weeks, 0 Days and 9:51:14 Hours
TLJimmy
HATES CATS, LUVS PUSSIES
I also heard TRE was unecessary on original "97 ecu, and you are right, 5th and 6th are slightly richer to compensate for ram air...
Ride it like you stole it. From Randy's pages: Quote:
To do list:Bitubo rear shock;1kg/mm front springs;Gold valves;'Busa MC with gold 6-pot calipers;braided front brake line;black paint;speedo-healer;TLR swingarm swap;aluminium chequer plate undertail;rob a bank; |
#20 (permalink) | ||
Member #14541
TLJimmy
![]() But yeah, if you turn up with a shopping list they'd probably just laugh at you.
| Tags |
| 1997, recalls |
| Thread Tools | |
| Display Modes | |
