made a color mistake - looking for suggestions - TLZone Forums
This box pays the bills.
Old 08-26-2008, 07:56 PM   #1 (permalink)
racrboy's Avatar
Member #1967
Sportsbike: 2001 TLR
Riding Experience: 20+
Trader Rating: (4)
Life Wasted on TLZone: 3 Days and 10:04:57 Hours
racrboy
Send a private message to <!-- google_ad_section_start(weight=ignore) -->racrboy<!-- google_ad_section_end --> Steve is the prettiest admin
I have a set of Gilles rearsets and they are the anodized titanium color. Should have gotten them in black. Dont want to powdercoat them as they are too pretty, and to re-anodize them is far too costly. Anyone have any suggestions?
Want to see what i have done? Look in my garage....
Old 08-26-2008, 08:31 PM   #2 (permalink)
Scummy's Avatar
Member #7779
Sportsbike: '03 TL1000R
Trader Rating: (6)
Life Wasted on TLZone: 1 Week, 2 Days and 3:50:50 Hours
Scummy
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Scummy<!-- google_ad_section_end --> Steve is the prettiest admin
Sell them and get the color you want.
Old 08-26-2008, 09:24 PM   #3 (permalink)
TLOTM Sept '08
D'Ecosse's Avatar
Member #12967
Sportsbike: TLS; Daytona; SV650S
Trader Rating: (4)
Life Wasted on TLZone: 1 Month, 0 Weeks, 5 Days and 0:14:36 Hours
D'Ecosse
Send a private message to <!-- google_ad_section_start(weight=ignore) -->D'Ecosse<!-- google_ad_section_end --> Steve is the prettiest admin
Anodizing typically similar cost to powdercoat.
You'll have an extra step though because they'll need to be etched first.
But black is usually cheapest because they always have stuff going on so can 'batch' it. Relative to cost of your parts, it shouldn't be that significant
One thought too is to not do all the parts - especially with the Ti, it would be a nice contrast to do a mix n match on black
Like this, but with your Ti on Black (or black on Ti)
Old 08-27-2008, 01:31 AM   #4 (permalink)
TLJimmy's Avatar
Member #14541
Sportsbike: '97 TL1000Sv
Riding Experience: 22yr+time off 4 bein bad
Life Wasted on TLZone: 2 Weeks, 0 Days and 9:51:14 Hours
TLJimmy HATES CATS, LUVS PUSSIES
Send a private message to <!-- google_ad_section_start(weight=ignore) -->TLJimmy<!-- google_ad_section_end --> Steve is the prettiest admin
The'd look perfect on my bike, I'll pay postage....
Ride it like you stole it.
From Randy's pages:
...Newbie riders should simply skip the TL and go straight to the morgue.
Mods so far: 2 Bros mufflers;homemade TRE;Airbox mod;'97 temp sensor mod;Iridium plugs;TLR bellmouths;OEM-style smoked screen;HH sintered pads front and rear;Metal Gear rotors with gold carriers;removed OEM mirrors and mounts;bar-end mirror with cut down stock weight as spacer; chopped rear fender; DID gold x-ring heavy duty chain;2 up on rear sprocket;damper mount mod for easy tank lifting;forks up-in-the-triples 7.5mm;Riflemans clear clutch cover and 1/5 throttle insert;Barnett clutch springs;Mini CF look indicators front; mini chrome LED's rear with resister;2.5wt oil in stock damper;yosh-box re-map;
To do list:Bitubo rear shock;1kg/mm front springs;Gold valves;'Busa MC with gold 6-pot calipers;braided front brake line;black paint;speedo-healer;TLR swingarm swap;aluminium chequer plate undertail;rob a bank;
Old 08-27-2008, 07:52 AM   #5 (permalink)
Member #9870
Sportsbike: 2001 TL1000R
Trader Rating: (14)
Pictures: 13
Life Wasted on TLZone: 6 Days and 18:10:27 Hours
keeena
Send a private message to <!-- google_ad_section_start(weight=ignore) -->keeena<!-- google_ad_section_end --> Steve is the prettiest admin
You may be taking a chance getting them anodized; crappy work will fade quickly. OEMs tend to have quality anodizing of their products. So I'd say definitely sell them. List them in the FS section; I'm sure they will sell fairly quickly.
Old 08-27-2008, 08:29 AM   #6 (permalink)
wsmc831's Avatar
Member #368
Sportsbike: 1997 TLS 2002 KTM 300MXC
Riding Experience: First bike, 1983
Life Wasted on TLZone: 4 Days and 20:45:01 Hours
wsmc831
Send a private message to <!-- google_ad_section_start(weight=ignore) -->wsmc831<!-- google_ad_section_end --> Steve is the prettiest admin
I would just powder coat them....though that's partly because I do my own. Plenty of color/style options out there if you don't want gloss/mid/flat black....
1997 TLS - the classy green one. Yosh full system, custom high mount. PcII, Sharkskinz TLR one piece race tail with anti draft undertail, Zero gravity double, Pro-tek rearsets, Hyperpro 916 style damper, corbin seat, Vortex triple clamp, airtech hugger, Penske/Lindeman rear shock and linkage, Lindeman superbike fork valve job, Marchesini 10 spoke Black, Gsxr 750 6 piston calipers and larger m/c, SS brake lines front and rear, Braking Wave Rotors front, milled gsxr rotor rear, billet preload adjusters, airbox reworked, Graves clutch cover, gsxr 1000 rear caliper, Stealth tri metal rear sprocket, Rk 520 chain, sprocket specialists front, KN air filter, Black/gold Pazzo levers, Vortex black gas cap, Ti bolts, ceramic coated headers, 05 1k clip ons, 4 lb battery.
Old 08-27-2008, 09:20 AM   #7 (permalink)
tl1000rman's Avatar
Member #1294
Sportsbike: '02 Yellow TL1000R
Riding Experience: Squid for life ...
Trader Rating: (20)
Life Wasted on TLZone: 5 Days and 17:38:09 Hours
tl1000rman
Send a private message to <!-- google_ad_section_start(weight=ignore) -->tl1000rman<!-- google_ad_section_end --> Steve is the prettiest admin
Originally Posted by D'Ecosse View Post
Old 08-27-2008, 12:55 PM   #8 (permalink)
TLOTM Sept '08
D'Ecosse's Avatar
Member #12967
Trader Rating: (4)
D'Ecosse
Originally Posted by tl1000rman View Post
You want to know how much those are
$280!!!!!! yes, you heard it!!! ($260 if you want single colour)
Bohemian Racing here in the Bay Area sells them - they are Chinese but look pretty decent.
That pic above is from an actual user who posted review. (whole review here)
OK - they're not Gilles or Sato - but worth a shot for me at that price.
Got excellent feedback on the Bay Area Riders forum
Here is the thread from the local site with contact info etc.
I'm undecided on black on gold or gold on black for mine.
Old 08-27-2008, 08:25 PM   #9 (permalink)
racrboy's Avatar
Member #1967
Trader Rating: (4)
racrboy
OK Guys. Back on track. Anyone out there with some black Gilles they want to swap?
color, made, mistake, suggestions
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
The TLZone Blog:
