Forks leaking. Sell the TLR or fix the forks? - Page 2 - TLZone Forums
This box pays the bills.
Old 08-25-2008, 02:44 PM   #11 (permalink)
i8marcus's Avatar
Member #9967
Sportsbike: 98 TLR & 02 YZ250
Riding Experience: 12+ Years
Life Wasted on TLZone: 1 Week, 5 Days and 18:17:32 Hours
i8marcus
Send a private message to <!-- google_ad_section_start(weight=ignore) -->i8marcus<!-- google_ad_section_end --> Steve is the prettiest admin
Check with Speedking for the Busa forks....He's usually got some for sale at a good price. Check the "for sale" section
1998 TL1000R
Yoshimura RS-3 Exhaust, Forks reworked by Racetech, RaceTech valved Showa Shock/Eibach Superbike Spring, Ivan's TRE, Brembo HP Rotors, Brembo 19x18 Clutch M/C, Brembo 19x18 Brake M/C, EBC HH Pads, Galfer SS Brake & Clutch Lines, Hyperpro RSC Damper, CFM/Woodcraft Rearsets, CFM/Woodcraft Clip-on's, Stealth Tri Metal Sprocket 17/42, DID Chain, Michelin Pilot Powers, BMC Air Filter, Zero Gravity Windscreen, GSXR Race Tail.
"Brake later and open the throttle before normal" -Valentino Rossi
Old 08-25-2008, 04:13 PM   #12 (permalink)
SVonhof's Avatar
Member #3403
Sportsbike: 2001 Blue/White TL1000R, '96 CBR600F3 (sold), '92 Kawi ZX-6D (long gone)
Riding Experience: 11
Life Wasted on TLZone: 17:43:00 Hours
SVonhof
Send a private message to <!-- google_ad_section_start(weight=ignore) -->SVonhof<!-- google_ad_section_end --> Steve is the prettiest admin
PM sent. Thanks. Saw it the first time, but didn't act on it until now.
Scott Vonhof
My Web Site, Home Theater, TLR
**HD Screen Captures**
Old 08-25-2008, 06:59 PM   #13 (permalink)
cyclecamper's Avatar
Member #4340
Riding Experience: 40 years
Trader Rating: (24)
Life Wasted on TLZone: 1 Week, 1 Day and 2:35:42 Hours
cyclecamper
Send a private message to <!-- google_ad_section_start(weight=ignore) -->cyclecamper<!-- google_ad_section_end --> Steve is the prettiest admin
Your shop fucked up the job completely, and/or just didn't take it far enough.
1) If your'e not tightening the axle in the correct sequence, it will destroy seals quickly when it forces the fork into incorrect geometry.
2) If #1 was ever wrong, you need seals and sliders and dust covers etc. If your male lower legs look OK (not worn thru the chrome) it's all easily fixed.
3) Not too hard to do yourself with a few tools, but lots of shops fuck it up IMHO. Forks go to a susension shop or you learn to do it yourself.
4) If its bottoming, chances are REALLY GOOD that they didn't refill the fluid to the correct level. The remaining trapped air creates a very progressive spring, so the fluid level is critical because it sets that volume of trapped air and determines how progressive the anti-bottoming air-spring is. That's how you set it to prevent bottoming.
Old 08-25-2008, 08:48 PM   #14 (permalink)
SVonhof's Avatar
Member #3403
SVonhof
Good information, partially too late as I would have taken it elsewhere the first time! But thanks for the info. I will heed that on this next job, whatever that ends up being. I am taking everything in right now and need to figure out my next move. Good thing is, this is not my sole transportation and I typically only ride a day a week or so.
Scott Vonhof
Old 08-26-2008, 12:28 AM   #15 (permalink)
Sportsbike: 97 tl1000s
Riding Experience: 32 years
Trader Rating: (6)
Life Wasted on TLZone: 1 Month, 0 Weeks, 0 Days and 0:23:35 Hours
The Ring-In don't ride with me I'm a rain god and a C***
if they bottomed out its most likely it needs a spring upgrade. check the bus forks will have springs enough to suit your weight.
oggi knobs. anodised barends, heli bars. arrow cans, custom rear peg mounts, white power shock, hugger, undertail, clear tail light lens, PC 11 , modded airbox, K&N air filter, 6 spots, braided front lines, polished rims and colour matched painted wheel spokes, fan override switch , TRE, tank bra, american high capacity battery, sv650 grab rail,RGV250 front guard.
Old 08-26-2008, 03:46 AM   #16 (permalink)
the gringo's Avatar
Member #14449
Sportsbike: 99 TLR....ZX9R
Riding Experience: prefer the woman on top
Pictures: 5
Life Wasted on TLZone: 1 Week, 0 Days and 5:21:18 Hours
the gringo
Send a private message to <!-- google_ad_section_start(weight=ignore) -->the gringo<!-- google_ad_section_end --> Steve is the prettiest admin
when you remove the forks, inspect the stanchons with a magnifying glass for tiny chips in the chrome. what happens is road crud hits the forks and puts tiny chips in the plating, these chips are razor sharp as they flake off and slice through the seal lips as they bounce up and down.
when you find them you can polish them out.....CAREFULLY.
i replaced my seals then 1000miles later they were leaking again. the people that re-vamped my forks told me this is what happens.
so now 4000 miles later.....no leaks.
1999 TLR, (work in progress), Yoshi map, K&N filter, joes air box mod, +2 teeth rear sprok -1 front sprok, TRE (but dont think it duz much), stubby carbon cans, maxton rear shock, maxton modified forks dropped 10mm,Metzeler race-tec's, braided hoses, aprilia mirrors, Stomp grips, blue screen & light cover, oh and resprayed.........."is it illegal to marry a bike?"
Ashes to Ashes Dust-to-Dust, Life is short so Party We must!
Old 08-26-2008, 04:58 AM   #17 (permalink)
Trader Rating: (6)
I use a small sharpening stone and hold it flat on the surface and rub gently
Old 08-26-2008, 08:28 AM   #18 (permalink)
TLR-Billbo's Avatar
Member #1415
Life Wasted on TLZone: 1 Month, 1 Week, 4 Days and 20:34:09 Hours
TLR-Billbo is dreading winter...but its coming anyways
its junk, the bikes worthless now, you should just sell it to me for $100
*2005 SXR 800*Blowsion mat kit with side lifters*Blowsion billet bilge pump switch bracket*Rule 500GPH bilge*R&D billet angled reed spacers*R&D exhaust sleeve*Wamiltons scupper valve*Wamiltons stubby pump cone*relocated fuel fill and pickup*-4" hull*-1.5" handlepole*R&D intake grate*-4" stock ride plate*ODI locking grips*PWCgraphics.com graphics*intake snorkels removed*Blowsin billet engine mount keepers*HotRods crank assembly*R&D 6º ignition advance kit*Blowsion handlepole saver*
stuff for sale!
MySpace
Old 08-26-2008, 08:38 AM   #19 (permalink)
wsmc831's Avatar
Member #368
Sportsbike: 1997 TLS 2002 KTM 300MXC
Riding Experience: First bike, 1983
Life Wasted on TLZone: 4 Days and 20:45:01 Hours
wsmc831
Send a private message to <!-- google_ad_section_start(weight=ignore) -->wsmc831<!-- google_ad_section_end --> Steve is the prettiest admin
no reason to change forks, you may just be getting another headache. the oem forks work VERY well if they are valved and sprung properly..certainly better than stock forks off some other bike.
1997 TLS - the classy green one. Yosh full system, custom high mount. PcII, Sharkskinz TLR one piece race tail with anti draft undertail, Zero gravity double, Pro-tek rearsets, Hyperpro 916 style damper, corbin seat, Vortex triple clamp, airtech hugger, Penske/Lindeman rear shock and linkage, Lindeman superbike fork valve job, Marchesini 10 spoke Black, Gsxr 750 6 piston calipers and larger m/c, SS brake lines front and rear, Braking Wave Rotors front, milled gsxr rotor rear, billet preload adjusters, airbox reworked, Graves clutch cover, gsxr 1000 rear caliper, Stealth tri metal rear sprocket, Rk 520 chain, sprocket specialists front, KN air filter, Black/gold Pazzo levers, Vortex black gas cap, Ti bolts, ceramic coated headers, 05 1k clip ons, 4 lb battery.
Old 08-26-2008, 08:40 AM   #20 (permalink)
WSB Pit boss
dragonbro's Avatar
Member #74
Sportsbike: 2002 TL1000R b/w
Riding Experience: been there, done that!
Life Wasted on TLZone: 1 Day and 17:27:25 Hours
dragonbro
Send a private message to <!-- google_ad_section_start(weight=ignore) -->dragonbro<!-- google_ad_section_end --> Steve is the prettiest admin
Hey Scott...........DON'T SELL IT get the forks to a good shop and have them inspected Seals, springs, revalve job will probably run near $350. If you do end up going with Busa forks remember that the front fender mounts are different. You will have to modify the mounts to use the TLR fender
2002 TLR B/W . Yoshimura bolt on Titanium cans. Yosh box remap. Joe V airbox mod. plug in TRE. 17/41 sprockets. Zero Gravity double bubble screen. fan switch. HyperPro steering damper. Extreme Graphic Top Gun undertail. Ohlins rear shock.
Gear: Arai Quantum f. Joe Rocket GPX 1pc suit. Alpinestars Super Tech boots. Alpinestars GP-1 gloves----always wear it all
forks, forks?, leaking., sell
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
The TLZone Blog:
