You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. If you are already a member, but have forgotten your password, you can have it sent to your email address by using this form. |
LinkBack | Thread Tools | Display Modes |
#31 (permalink) |
Member #13818
Life Wasted on TLZone: 1 Day and 2:53:29 Hours
oldman_d
I took the cluster off and accessed it from the rear. I posted my gauges and somewhat of a how-to on TL Planet. Here's the link
http://www.tlplanet.com/forums/showt...ht=blue+gauges Here's a pic of what it looked like first time around when I only put three LED's at the top. It worked, but they weren't as bright as they are now. I was also thinking about going with a plug and play bulb, but then I think you would end up with a hot spot at the top and the bottoms still not lighting up as well as you would want. ![]() That's why I tore it apart again and put five in each, that way I could spread them around to achieve more of any even lighting. I would also like to say that in person, the gauges don't have any hot spots to the naked eye, something about the camera, it magnifies the hot spots in the pick. |
#32 (permalink) | |
Member #9960
Sportsbike: TL1000R
Life Wasted on TLZone: 6 Days and 4:04:46 Hours
Juice_Man
so you solder the leds together and feed them through the hole where the stock bulb went and you try to spread them around inside as much as possible?
![]() Quote:
Time is money so I stay late!!! |
#33 (permalink) |
Member #11012
Sportsbike: late 97TLS
Trader Rating: (12)
Life Wasted on TLZone: 1 Week, 6 Days and 23:30:20 Hours
sector5
Just got my LED’S today they are:
NFLS-x30 Flexible Light Strip 1/2 Meter (19.5 Inch) long Non-waterproof Flexible Light Strip with 30 High Power LEDs 12 VDC Operation, Can be cut into 3-LED segments LEDs on highly flexible strip with adhesive backing I Had to buy two strips as OS cost me $16.95 each strip of 10 + $5.00 Post. ![]() I used I strip of 5 for the rev gauge and a strip of 4 for the Speedo ![]() Did not like that I had a uneven light on the gauge due to factory shading so I removed it with a blade then placed blue contact over to get a even light over the hole gauge. ![]() ![]() I used some foam box not to bend the needle pin. ![]() And in the end. ![]() ![]() Only thing left for me to do is work out + - sides on the back. If any one knows as I have my bike in 100 bits so no power ![]() So all in $20 Mod
Busa 6 Pots GOLD, Busa GOLD Rear Calliper, Busa M/C 5/8, Braided Goodrich Lines all round, 520 17/42 Chain and Sprocket, Speedo Healer, Power Commander 3USB,Wideband Commander with LCD, Multi Hub, TLR Hydro Clutch with Busa Master, Air Box Mod, K&N High-Flow Filter, Led Turn and Tail Lights, Bitubo Rear Shock, Rifleman 1/5 Throttle Insert, Pazzo Levers, Scott’s Oil Filter, 5bolt VAN Billet Clutch Pressure Plate, VAN Billet Sprocket Cover, VAN Billet Starter Cover, VAN Billet Rear Brake Res and Spring, VAN Billet Clear Clutch Cover, Smart TRE, Blue LED Gauges, Fan Switch Mod, Clutch Switch Mod, Gap Mod. http://www.skinna.net/piss/suzuki.swf |
#34 (permalink) | |
is Speedking's swimming coach
Member #4632
Trader Rating: (20)
Life Wasted on TLZone: 3 Weeks, 3 Days and 4:12:15 Hours
Kamikuza
thinks Speedking needs to
rethink the Speedos ...
Sector - that looks like the best idea so far
got an ebay link for those please?
FYI OEM prices - check here before your dealership rips you off! |
#35 (permalink) |
Member #11012
Trader Rating: (12)
sector5
i have one more set left as had to buy to lots (as not in the US 30 min buy)$20 shipped or you can get them at http://www.superbrightleds.com/
#36 (permalink) |
Member #3577
Sportsbike: Only the best ... '99 TLR
Riding Experience: 14 years (3 Off-road)
Pictures: 5
Life Wasted on TLZone: 2 Days and 7:28:42 Hours
UKbiker
Anyone considered the easy option ? .... Get some LED's and point them at the face of the gauges from somewhere on the upper fairing. Light them up from outside so to speak
![]() TLR's |
#37 (permalink) | |
Member #4632
Trader Rating: (20)
Kamikuza
That would naff - like you're trying to be DJ on your bike
#38 (permalink) | |
Member #4263
Sportsbike: A '97 TLS...What Else?
Riding Experience: 24 years
Trader Rating: (24)
Pictures: 12
Life Wasted on TLZone: 1 Week, 4 Days and 9:02:55 Hours
Aredubu
#39 (permalink) |
Member #11012
Trader Rating: (12)
sector5
lay out fot the S
#40 (permalink) |
Member #3577
Pictures: 5
UKbiker
Well its not that bad an idea
... Some directional LED's would only light up the clock face, but from the outside. If they are behind the top fairing no ones gonna see them. Just a thought trying to save messing about !! TLR's |
| Tags |
| gauges!!!, show |
| Thread Tools | |
| Display Modes | |
