NOT SURE IF I CAN ASK ABOUT THIS HERE - TLZone Forums
Go Back   TLZone Forums > General Forums > SV650/1000 and Others
SV650/1000 and Others SV650/1000, V-Strom/Bimota, Cagiva?etc....
This box pays the bills.
Old 07-06-2008, 10:43 PM   #1 (permalink)
STAYBG's Avatar
Member #14015
Sportsbike: 97 tls
Riding Experience: 5 yrs
Life Wasted on TLZone: 1 Week, 2 Days and 4:20:07 Hours
STAYBG
Send a private message to <!-- google_ad_section_start(weight=ignore) -->STAYBG<!-- google_ad_section_end --> Steve is the prettiest admin
my girlfriend just bought a 08'' ninja 250r and she want a gear indicator. whats involved with installing these and whats the requirements?
Old 07-07-2008, 12:18 AM   #2 (permalink)
TLOTM Sept '08
D'Ecosse's Avatar
Member #12967
Sportsbike: TLS; Daytona; SV650S
Trader Rating: (4)
Life Wasted on TLZone: 1 Month, 0 Weeks, 5 Days and 0:14:36 Hours
D'Ecosse
Send a private message to <!-- google_ad_section_start(weight=ignore) -->D'Ecosse<!-- google_ad_section_end --> Steve is the prettiest admin
Probably should be in one of the other forums - it may get moved!
Anyway, you need something like an Acumen DG8 - this compares the tach signal with the wheel speed signal & calculates then displays the appropriate gear.
I'm not sure if the 250 Ninja has electronic speed signal? Think it might be mechanical - cable drive? No matter even if it is - you can add an auxiliary speed sender to provide the input for that.
Not difficult to install or wire up.
You can get in the US from somewhere like RiderStation
Edit - I see the 08 has a new speedo, possibly electronic drive which would make it easier - you just need the DG8 in that case - universal model most likely.
Old 07-07-2008, 02:15 AM   #3 (permalink)
SQDBIKE Admin
crashtd's Avatar
Member #102
Sportsbike: '04 R1
Riding Experience: 2 weeks
Trader Rating: (29)
Pictures: 12
Life Wasted on TLZone: 2 Weeks, 2 Days and 4:30:19 Hours
crashtd need motorcycle bloggers, inquire within.
Send a private message to <!-- google_ad_section_start(weight=ignore) --><b><i>crashtd</b></i><!-- google_ad_section_end --> Steve is the prettiest admin
here is as good of a place as any. the folks on ninja6zone.com might know something further though.
tlzone - ninja6zone - rsvzone - tuonozone - own3douput - postwhore - haiku-to-go
TLZone Forums Staff - Resident Tortfeasor
Old 07-07-2008, 10:03 AM   #4 (permalink)
STAYBG's Avatar
Member #14015
Sportsbike: 97 tls
STAYBG
k i just called riderstation and they said that nobody makes one for any 08'' bikes, the speedo is cable driven on the 250r. but cant i use a indicator that is for a cable driven speedo bike? i dont need one with a direct fit harness. i can wire the thing in.
Old 07-07-2008, 11:06 AM   #5 (permalink)
TLOTM Sept '08
D'Ecosse's Avatar
Member #12967
Trader Rating: (4)
D'Ecosse
As in my first reply, just get the universal kit plus the cable-speedo accessory - they don't list the speed sender kit on the website but you can ask them at riderstation to get it for you.
You don't actually even need the specific Acumen sender - you can use any Hall effect Speed sender. But convenient to get in one package.
Note that the update rate with the speed sender will be quite slow - especially in the lower gears. Use the maximum number of magnets in the kit to get the fastest response.
Here's a thread of how it turned out on my Triumph before the Digital gauges (I combined the gear indicator with an electronic speedo retro using the DG8 speed sender for both) Ignore the first part about the gauge conversion and check the pics on the speed sender install on the swing-arm/sprocket.
Check the video link & you can see how the thing responds much slower in the lower gears (because wheel speed is lower) I used 6 trigger magnets. Overall that bike speed is pretty low though, the bike was on the rear stand. In actual use, it is most helpful for avoiding trying to find "7th" gear
Old 07-07-2008, 12:54 PM   #6 (permalink)
STAYBG's Avatar
Member #14015
Sportsbike: 97 tls
STAYBG
looks like alot of work. and not very responsive.
Old 07-07-2008, 01:17 PM   #7 (permalink)
TLOTM Sept '08
D'Ecosse's Avatar
Member #12967
Trader Rating: (4)
D'Ecosse
I agree about the response time - however not that much work to install, even with the speed sender (ignore all the speedo mod stuff that is part of the same post)
Here is another option from Engear
- these guys claim to have fast update response although I have no personal experience of them. You would still need a speed sender - on the linked page go to the "sensors" link at the top of the page - the sendr is the first item. That one has advantage in that no magnets to mess with, just line up the detector opposite sprocket or rotor bolts.
Here's a video from YouTube with the Engear
Old 07-07-2008, 03:19 PM   #8 (permalink)
STAYBG's Avatar
Member #14015
Sportsbike: 97 tls
STAYBG
that one looks pretty responsive.
Old 07-07-2008, 03:30 PM   #9 (permalink)
STAYBG's Avatar
Member #14015
Sportsbike: 97 tls
STAYBG
yeah they got what i need. thanks for the info.
Old 07-09-2008, 01:49 AM   #10 (permalink)
CMonkee's Avatar
Member #5107
Riding Experience: Intermediate (25 years)
Life Wasted on TLZone: 1 Week, 4 Days and 6:19:20 Hours
CMonkee
Send a private message to <!-- google_ad_section_start(weight=ignore) -->CMonkee<!-- google_ad_section_end --> Steve is the prettiest admin
check out the veypor units. easy to install, not too expensive and can be used on other bikes.
just my .02
C
A monkey a day keeps the bananas away!
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
The TLZone Blog:
