SV1000 Bars? - TLZone Forums
Go Back   TLZone Forums > General Forums > SV650/1000 and Others
SV650/1000 and Others SV650/1000, V-Strom/Bimota, Cagiva?etc....
This box pays the bills.
Old 06-26-2008, 03:47 AM   #1 (permalink)
Member #12260
Sportsbike: 1998 tlr1000
Riding Experience: 25 years of dirt, 10 road
Life Wasted on TLZone: 1:05:52 Hours
bald2
Send a private message to <!-- google_ad_section_start(weight=ignore) -->bald2<!-- google_ad_section_end --> Steve is the prettiest admin
Cool SV1000 Bars?
Hi guys, just tried fitting some CR high mx bars to my 06 SV1000, but all the cables, wiring and hoses are to short! No amount of rerouting seems to help, any help would be greatly appeciated, or what bend of aftermarket bars are people out there using to get rid of the horrible originals.Ps I have stayed with the 7/8 size clamps! Thanks Baldz.
Old 06-26-2008, 09:53 AM   #2 (permalink)
wsmc831's Avatar
Member #368
Sportsbike: 1997 TLS 2002 KTM 300MXC
Riding Experience: First bike, 1983
Life Wasted on TLZone: 4 Days and 20:45:01 Hours
wsmc831
Send a private message to <!-- google_ad_section_start(weight=ignore) -->wsmc831<!-- google_ad_section_end --> Steve is the prettiest admin
Well, if you are looking for information on longer cables, I would contact Heli bars and ask them, may even have info on their site as many of their clip ons require longer cables.
1997 TLS - the classy green one. Yosh full system, custom high mount. PcII, Sharkskinz TLR one piece race tail with anti draft undertail, Zero gravity double, Pro-tek rearsets, Hyperpro 916 style damper, corbin seat, Vortex triple clamp, airtech hugger, Penske/Lindeman rear shock and linkage, Lindeman superbike fork valve job, Marchesini 10 spoke Black, Gsxr 750 6 piston calipers and larger m/c, SS brake lines front and rear, Braking Wave Rotors front, milled gsxr rotor rear, billet preload adjusters, airbox reworked, Graves clutch cover, gsxr 1000 rear caliper, Stealth tri metal rear sprocket, Rk 520 chain, sprocket specialists front, KN air filter, Black/gold Pazzo levers, Vortex black gas cap, Ti bolts, ceramic coated headers, 05 1k clip ons, 4 lb battery.
Old 06-26-2008, 10:22 AM   #3 (permalink)
BikePilot's Avatar
Life Wasted on TLZone: 1 Month, 0 Weeks, 5 Days and 10:50:33 Hours
Also you might check on other oem parts that may do the trick. I suspect V-strom parts would fit and would be longer (I haven't tried it, just guessing here). IIRC TL guys often use a yamaha SR125 (I think) clutch cable as its longer and seems to work well.
9k mile summer ride report
Old 07-16-2008, 12:44 PM   #4 (permalink)
Member #12401
Sportsbike: 2002 Yamaha Roadstar...sold 2007 SV1000S Black
Riding Experience: Riding since 09/02
Life Wasted on TLZone: 0:23:33 Hours
rauchman
Send a private message to <!-- google_ad_section_start(weight=ignore) -->rauchman<!-- google_ad_section_end --> Steve is the prettiest admin
I picked up a 2007 SV1000S last week and ordered Convertibars for it. They have a kit that is roughly $185 that has all the cables/brake lines extended to give a 4" reach over stock. Might want to check them out.
http://convertibars.com
Old 07-16-2008, 05:03 PM   #5 (permalink)
Member #14480
Sportsbike: 2003 SV1000S, 2003 TL1000R
Life Wasted on TLZone: 18:14:25 Hours
yx302
Send a private message to <!-- google_ad_section_start(weight=ignore) -->yx302<!-- google_ad_section_end --> Steve is the prettiest admin
try speigler. i think you can by the cables from them apart from the kit.
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
The TLZone Blog:
