project? - TLZone Forums
Go Back   TLZone Forums > General Forums > SV650/1000 and Others
SV650/1000 and Others SV650/1000, V-Strom/Bimota, Cagiva?etc....
Old 02-14-2007, 04:05 PM   #1 (permalink)
Elreq's Avatar
Member #1037
Sportsbike: TLR 03 B/W TLR 00 - Project in progress
Riding Experience: a little lots
Life Wasted on TLZone: 4 Days and 16:06:37 Hours
Elreq
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Elreq<!-- google_ad_section_end --> Steve is the prettiest admin
project?
I have 2 things id really like to do.
1st a single side swing arm. for those who have ridden or done it is there a difference in handling. and where would i look to get this done. ido i just buy the part and put it on or will it half to be a one-of
2nd i would really like to set up the exhaust to come out like the beulls. only have an exhaust tip come out on either side of the bike. i am assuming i would have to cut my lower fair but just wondering if you had any tips. id rather try to keep a muffler on it and not straight pipe it. plus id love to do it with out cutting my Fairng.
so what are your thoughts or helpfull ideas that this forum is so known for.
My First mod....... Anodized Blue Swing Arm Spools.....YEAH?!!
Frequent Mods completed:
Pair valve removal
Air box mod
Chucks stock exhaust mod
In-line fuel filter
Old 02-14-2007, 04:40 PM   #2 (permalink)
Loki-TLR's Avatar
Member #7563
Sportsbike: TLRS
Riding Experience: not enough
Trader Rating: (7)
Life Wasted on TLZone: 4 Weeks, 1 Day and 17:25:46 Hours
Loki-TLR Loki-TLRS
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Loki-TLR<!-- google_ad_section_end --> Steve is the prettiest admin
First try to find the thread with pics and info on this subject. Bolt on? wishfull thinking
I think a singlesider is a bit heavier. But If you can find one with almost the same length as the standard swinger and get the suspension(ratio) right you should hardly feel the difference.
Check out the thread Fiche-man is running about his street TLS..
The coolest car alarm tester by far - TL1000S
Old 02-15-2007, 05:10 AM   #3 (permalink)
mullerjd's Avatar
Member #9443
Sportsbike: 00 SV650, 01 SV650S, 02 SV650S, 01 TLR fighter, 05 BMW R1100S, 87 BMW K75C, 69 BMW R60
Riding Experience: since 5yrs old
Life Wasted on TLZone: 5 Days and 14:41:27 Hours
mullerjd
Send a private message to <!-- google_ad_section_start(weight=ignore) -->mullerjd<!-- google_ad_section_end --> Steve is the prettiest admin
What bike are you talking about? A couple guys on Svrider have done it to first gen SVs. I think it's quite a bit of work to do though.
01 TLR Fighter, 00 SV, 01 SVS, 02 SVS, 05 BMW R1100S, 87 BMW K75, 69 BMW R60US
Old 02-15-2007, 01:20 PM   #4 (permalink)
Elreq's Avatar
Member #1037
Elreq
im talking a 03 TLR
Pair valve removal
Air box mod
In-line fuel filter
Old 02-15-2007, 02:03 PM   #5 (permalink)
BikePilot's Avatar
Trader Rating: (18)
Life Wasted on TLZone: 4 Months, 2 Weeks, 5 Days and 19:37:37 Hours
IMHO its the kind of thing where if you have to ask its probably way more involed than your prepared for. Doing an SSA right requires a lot of knowledge and practical skill, dito for the exhaust. Have a look at fiche-man's thread and if it all makes sense and seems do-able to you then have at it and post up pics
I think at one time there may have been aftermarket, tubular (Uno perhaps) SSA's available as direct bolt-on. I'm not 100% sure though and they likely cost more than a TLR is worth these days.
good luck
Old 02-15-2007, 04:05 PM   #6 (permalink)
Elreq's Avatar
Member #1037
Elreq
i like this ssa
http://www.cycleworld.com/article.as...article_id=278
Pair valve removal
Air box mod
In-line fuel filter
Old 02-15-2007, 04:15 PM   #7 (permalink)
Elreq's Avatar
Member #1037
Elreq
i was more looking for help in the area of someone might know a closely compatible SSA that i could mock in. and i ask because it is always better to ask and learn from someone elses mistakes.
on a side note WHY DID THIS GET MOVED I HAVE A TLR NOT AN SV? DID I POST THIS IN THE WRONG PLACE OR DID IT GET MOVED?
Pair valve removal
Air box mod
In-line fuel filter
