Marchesini Rims. How to tell if......
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Marchesini Rims. How to tell if......
    o2w
    o2w is offline
    Silver Subscriber o2w's Avatar
    Jun 2003
    Sydney, Australia
    1,427
    Heres the scoop.
    A while ago, I bought a pair of Marchesini rims intending to mount them to the TLR. Following so far...good.
    What I wanted to know is.
    How can you tell if they are Aluminium or Magnesium? Is it weight alone or is magnesium magnetic? I know aluminium isn't, but so far, none of my magnets have proved definative.
    Also I have noticed that my rear cush drive is different to what is pictured on marchesini's website. My cush drive has round bushes, most of the other marchi's I have seen seem to have lobe type bushes. make sense?
    These rims came from Kawasaki's WSB team, so I'm presuming they are good, but how good?
    Anyone......?
    A WARNING to everyone
    WSB Pit boss tornado's Avatar
    Nov 2004
    Lossiemouth
    6,279
    hit it with a blowtorch to see if it catches fire
    depends on the alloy ingredients for magnetism, the tl cylinder head covers are slightly magnetic.
    GP Champ gixxstar's Avatar
    Oct 2004
    1,615
    easiest way to tell is at the hubs. The magnesium wheels are more of a straw color. In places where they've been scratched the metal will be dark. Aluminum will always look like aluminum. As far as I know Marchesini never bothered coating the wheels. I know that there's a date stamp on the Magnesium ones too.
    o2w
    o2w is offline
    Jun 2003
    Sydney, Australia
    1,427
    Thanks Gixxstar
    That confirms it....I bought a pair of Magnesium Marchesini's for $600AUS. SCORE!!!
    I guess the only downside is that the front is a 10 spoke and the rear is a 5 spoke.
    who's a happy boy then......
    BTW. My cush drive is the same as yours gixxstar. Is it an old pattern?
    GP Champ TL Lurker's Avatar
    Mar 2003
    Sumter, SC
    1,519
    I'm still trying to figure out what size rotors go on my marchesini rims!!! AAAAARRRGGGGHHH!!!
    A Lurker Once Again...
    o2w
    o2w is offline
    Jun 2003
    Sydney, Australia
    1,427
    Quote Originally Posted by TL Lurker
    Do you need the hole spacing dimensions?
    I've got a set of 305mm Cast Iron Brembo Rotors that came with these rims (forgot to mention that didn't I ).
    Not sure whether to run it as is with stock TLR calipers (which should run 320mm disks), or to change front forks with a Duc.
    May 2003
    milford ct
    29
    why would there be a date stamp in them and where would i find it on the rim?
    Oct 2004
    1,615
    Quote Originally Posted by wtl1000r
    It's usually on the hub and the reason that I've been told is they are only intended to be used for a few years before you toss them but who does that?
    Oct 2004
    1,615
    Quote Originally Posted by o2w
    Thanks Gixxstar
    That is a good deal. I have old wheels from a big AMA team as well. They didn't turn out to be off the shelf stuff at all and I had to get some help from one of their mechanics to acquire the right parts and it still took some machining on my end for wheel spacers but it all worked out well. There are two different hub types and neither of them were the same as the standard Marchesini magnesiums that I've seen. Still trying to figure out where I'll be getting these weird offset sprockets. My favorite part has always been the rear rotor.
    o2w
    o2w is offline
    Jun 2003
    Sydney, Australia
    1,427
    Quote Originally Posted by gixxstar
    I think AFAM sprockets should work. That's what I have on my carrier and mine "looks" the same as yours.
    BTW. Who makes the rotor you are using?
how to tell if a rim is magnesium
marchenesi wheels tl1000r
marchesini wheels australia
marchesini wheels date stamp
marchesini wheels have m stamped on them
