Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Like Tree2Likes
Thread: hydraulic clutch conversion
    GP Champ stu_m's Avatar
    Sep 2006
    hull east yorkshire
    1,195
    Just done this to my TLS
    And I don't know what all the fuss is about!
    Its just as bloody heavy!
    Although I do like the feel of it compared to the cable!
    I just need to replace the res cap as its got an anodized red one and looks crap!
    www.themotorbikeforum.co.uk
    I want to ride like hell on my TL
    Superbike Twin that tlr guy's Avatar
    Aug 2011
    Gloucestershire UK
    216
    I quite like the hydraulic clutch on my tlr - i thought it was a bit stiff when i first got the bike, so greased the lever pivot bolt which improved it.
    2002 TL1000R K1 - TRE, Pegasus performance cans, F.Fabbri frosted screen, Powerbronze undertray & Hugger, R&G bobbins, Wavy discs (probably chinese!!) Short levers, aftermarket heelplates & posh private plate!
    AMA Pit Boss paul.haydock's Avatar
    Oct 2005
    Chorley, Lancs
    3,229
    My TLR clutch is really light. As suggested, try and grease it up to ease it up.
    MTC pipes, Tre, Airbox mod, 1/5 throttle insert, fan switch, 16/39 gearing, PC11, +/- mods, Double bubble, Pilot Powers 2cts Hagon shock. intergrated L.E.D. indicators/rear lights, mirror indicators,rear view camera/monitor.
  4. #4
    Silver Subscriber Toledo's Avatar
    Jul 2005
    Kent, UK
    11,051
    If you get/fit one of Stu's adjustable clutch push-rods you get a constant "bite" point & the thing I like about the hyd' clutch conversion to my S is the fact that the feel stays constant...............it doesn't fade or get heavier. Cables for the S clutch need a lot of maintenance and in MHO need replacing frequently.
    I mean come on..............a virtual right-angle at each end of a clutch cable?
    Chris_TL1000 likes this.
    Mark.
    TLOTM JULY '11
    People I will not deal with: tl1000s/tl1000r Will/2012-krystal or whatever he decides he might/might not call himself.
  5. #5
    Silver Subscriber mikepeers007's Avatar
    Mar 2011
    Cheshire Manchester
    661
    Having had the displeasure of using a stock TLS clutch with barnett beef springs on a cable Its like trying to squeeze beech pebbles in your hand.
    Surely the hydro must be giving you something better.
    Toledo likes this.
    In god we trust!!! everyone else pays cash!!!
  6. #6
    Silver Subscriber ITSMESTEVE's Avatar
    Oct 2007
    Brisbane,AUSTRALIA
    4,259
    Try a Ducati / Aprilia radial master cylinder.
    Fingertip operation...no exageration.
    You'll love it.
    Just installed Brembo MCs and Calipers
    Red 98 TLR but looks like a yellow 02.Full Yoshi system ,airbox mod,Penske rear,SS brake lines,SteveTLS TRE,TLRstacker Sliders,Rifleman 1/5 throttle,TheRingIn swingarm pivots ,Pipercross filter,Pazzo levers,Vandriver tailrisers,Motty AFR Tuner,Projector headlights,GSXR forks,TheRingIn 30mm triple clamp offset, R1 Wheels ,brakes and swingarm,Ohlins steering damper...and counting. .......... PICK THE POINT IN THE SIG WHERE I JOINED TLZ
    Insert lame S vs R wisecrack here...
    "I refuse to prove that I exist," says God, "for proof denies faith, and without faith, I am nothing."
    Douglas Adams
    TLOTM Sept 2011........ BBOTM Nov 2011
  7. #7
    Sep 2006
    hull east yorkshire
    1,195
    Quote Originally Posted by Toledo View Post
    Yes thats the first thing I noticed about it when I tried it for the first time the feel is linear which I like
    My cable clutch was really snatchy even after welding the centre up!
  8. #8
    Sep 2006
    hull east yorkshire
    1,195
    Quote Originally Posted by ITSMESTEVE View Post
    You'll love it.
    I would love to its just I don't have Brembo money
  9. #9
    Jul 2005
    Kent, UK
    11,051
    I'm using a m/c off a 'Busa............
    Mark.
    TLOTM JULY '11
  10. #10
    Sep 2006
    hull east yorkshire
    1,195
    any better? might look in to something else for next year
