Disconneting tip over sensor, kickstand sensor, clutch sensor ok?
Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Disconneting tip over sensor, kickstand sensor, clutch sensor ok?
    Jun 2006
    Austin, TX
    215
    looking to eliminate some wiring and wanted to know if the removal of these things was done by simply soldering the wires together on tip over etc... and if many have done these?
    1999 TLR- k&n air filter, rifleman's 1/5 - nice ,TRE, PCIII, slash cuts
    next up: gearing change
    bitubo rear shock
    riser bars
    fan mod
    New Hampshire
    4,011
    The clutch switch and sidestand you can just jump the wires.
    The tip over switch is a bit more involved.
    Also some people say jumping the clutch switch effects the ECU, but I've had mine that way for almost ten years with no problems
    past rides
    2000 SV 650
    02 Aprilia Falco - sold to pay some bills
    98 TLR - will always be missed
    96 GSXR 750 great ol bike
    89 FZR 400 Race bike not really missed
    90 FZR 600 not missed
    81 GS 1100E still missed
    One Liter Duc Eater filrabey's Avatar
    Oct 2007
    Cornwall SW UK
    761
    Take a look at this thread for the TOS
    http://www.tlzone.net/forums/tl1000s...r-removal.html
    Take a look at this for clutch switch
    http://wotid.com/tls/content/view/18/56/
    Rescued a Black 97 TLS, been left out in the rain for a few years, stripped her n rebuilt her. Polished loads and loads to polish. Renthal Fat Bars with Scar Risers, Busa Forks, Ohlins damper, WLR Steering Damper Kit, Sam Tail Riser Mod, Gap Tray Mod, Tech G Billet Rear sets, Wavey's front and back, SV1000 belly Pan, Rifleman 1/5, GIpro ATRE, Thermostat Mod, Fuel filter Mod, Air box Mod, Zippytlsr Charging Mod, K&N air filter, Stubby cans, Vortex Fuel Cap, MT headlight unit, Gsxr1000 Digital Clocks, need to fit my Van Rear Res + Spring .......so much to buy, so much to keep from the lady!!
    Jun 2006
    Austin, TX
    215
    Quote Originally Posted by filrabey View Post
    better than the search option!
    bitubo rear shock
    riser bars
    fan mod
    Melbourne, Australia.
    29,848
    Measure the TOS resistance with it in it's normal position - I think it's either 60 ohms or 60K ohms I can't remember, I killed those brain cells.
    The ECU definitely gets a signal from the clutch switch, it's in the wiring diagram, I show in the link filrabey listed how the ECU definietly uses the signal for some mapping changes.
    Jun 2006
    Austin, TX
    215
    im going to switch to a cable clutch soon (looking for levers right now) and i was hoping to just eliminate that wiring if possible when i did...
    bitubo rear shock
    riser bars
    fan mod
    29,848
    If you read the link filrabey posted, I have instructions on how to eliminate it without affecting the ECU.
    GP Champ Patch11's Avatar
    Dec 2005
    over the ditch
    1,355
    I've had my TOS in my hand, bike running and rolled the TOS and the bike still runs I kinda like the kill switch thingy that the racers, jetski's and boats hav - can't remember what its actually called. Even funnier when ya mate tries to ride ya bike with the key in the ignition and the switch thingy out and you leave with it still attached to your glove.
    The idea is not to buy cheap but to buy right!
    29,848
    It takes a few seconds for the engine to cut out on a TOS fault. It doesn't happen instantly.
    Waiting for email confirmation TLDV8's Avatar
    Oct 2003
    Pluto LNG.
    8,879
    After having the TOS save both my TL's i wouldn't remove it.
    Repair bill $4000
    Repair bill $3000 +.
    http://i30.photobucket.com/albums/c345/manurewa/YL8Smallz.jpg
07 gsxr 600 tip over sensor bypass
2003 gsxr 1000 kickstand sensor
fzr400 kickstand switch
how to bypass the tip sensor on a suzuki gsxr
sv650 tip over sensor
tl1000 tip over sensor resistor
tl1000r tip over sensor
tl1000r tip over sensor location
tl1000r tip over sensor mod
tl1000r tip over sensor resistance
tl1000s tip over sensor
where is the tip over sensor in a 2003 tl r 1000
