Custom Frame Job ?'s
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By geofftl1000r
Thread: Custom Frame Job ?'s
    Evil Twin s14slide's Avatar
    Aug 2007
    Riverside, Communist Republic of California
    331
    I'm toying with the idea of taking my 97 TLS motor and using it to make a scrambler. I want to do a custom tube frame. This is still a year or two down the road, but I want to fill that time with knowledge acquisition. My question to you is, are there any pics of this being done with a TL motor and do any of you have any pointers to reading material? Frame design and the front end I understand no problem. I actually want to learn more about the relationship of the swingarm pivot pinion relationship. I've already done some reading on www.tonyfoale.com and www.victorylibrary.com, but Im always looking to pick the brains of my TL brethren.
    In a bajillion pieces............
    Awaiting Resurrection
    Resurrection started....23 June 2012
    12,777
    there are flat tracker frames available.
    also cagiva raptor frames may be a suitable donor
    have a look at some modern trail bikes to check modern thinking on placement
    Baby Twin baldrick's Avatar
    Feb 2007
    66
    flat tracker frames you say.
    any links?
    12,777
    Do some searches in the photo sections here
    been a few pictures posted up
    One Liter Duc Eater geofftl1000r's Avatar
    May 2008
    Salfords near Redhill
    863
    Maybe not the way to go.............
    The Ring-In likes this.
    " I started out with nuthin' and I still got most of it left"
    3,381
    A scrambler of sorts.......
    A couple flat trackers........
