Navigator Thermostat
Results 1 to 2 of 2
Like Tree2Likes
  • 1 Post By cancunia
  • 1 Post By Tuckshop Ted
Thread: Navigator Thermostat
    Jun 2011
    25
    I think this has probably been posted before, but thought I'd pull a couple of threads together for easy ref. The basic problem is that the standard Navi thermostat opens too soon for cold weather such as a normal British summer, that means there's a chance the engine will run on the 'cold' map. The simple fix is to fit a DL1000 thermostat or similar that opens around 88deg C. As the Suzuki part is quite expensive, there are alternates that can be used. I've pulled the info below from 2 threads elsewhere on the forum and pasted the text below.
    Post #8
    Thermostat mod problem
    Post #4
    Stoopid thermostat!!
    Suzuki DL1000 Part is 17670-06G50
    A popular alternative might be QTH209K
    Alternates from the 2 threads:
    Suzuki cars......
    1999
    Esteem GL
    L4 - 1.6L 97ci 1590cc type G16S - MFI GAS SOHC
    5 vehicles
    1995 - 2000*
    Esteem GL
    L4 - 1.6L vin 3 97ci 1590cc - MFI GAS SOHC
    1 vehicles
    1999
    Esteem GLX
    5 vehicles
    1995 - 2000*
    Esteem GLX
    1 vehicles
    1999
    Esteem GLX Plus
    5 vehicles
    1995 - 2000*
    Esteem GLX Plus
    2 vehicles
    1998 - 1999
    Swift Base
    L4 - 1.3L vin 2 79ci 1298cc - MFI GAS SOHC
    3 vehicles
    1995 - 1997
    Swift Base
    L4 - 1.3L vin 2 79ci 1298cc - TBI GAS SOHC
    2 vehicles
    2000 - 2001
    Swift GA
    4 vehicles
    1991 - 1994
    Swift GA
    L4 - 1.3L vin 3 79ci 1298cc - TBI GAS SOHC
    2 vehicles
    2000 - 2001
    Swift GL
    4 vehicles
    1991 - 1994
    Swift GS
    4 vehicles
    1991 - 1994
    Swift GT
    L4 - 1.3L vin 3 79ci 1298cc - MFI GAS DOHC
    Subaru models....
    1987 - 1990
    Justy DL
    L3 - 1.2L vin 7 1189cc - 2BBL GAS SOHC
    3 vehicles
    1987 - 1989
    Justy GL
    4 vehicles
    1988 - 1991
    Justy GL
    L3 - 1.2L vin 8 1189cc - 2BBL GAS SOHC
    1 vehicles
    1989
    Justy RS
    NISSAN MARCH I (K10)198212 - 199211
    DAIHATSUCHARADE ? (G10)197710 - 198304
    DAIHATSUCHARADE Mk II (G11, G30)198301 - 198705
    DAIHATSUCHARADE Mk III (G100, G101, G102)198701 - 199307
    DAIHATSUMOVE (L6, L9)199406 - /
    DAIHATSUHIJET Box (S85)199212 - /
    DAIHATSUHIJET Box198606 - 199010
    DAIHATSUHIJET Pickup198004 - 198304
    DAIHATSUHIJET Box197709 - 198304
    DAIHATSU850 Box (E65)198607 - 198912
    DAIHATSUHIJET Pickup (_U60)199212 - 199805
    SUZUKIALTO ? (SS80)198206 - 198512
    SUZUKIALTO Mk II (EC)198509 - 199311
    SUZUKISWIFT ? (AA)198310 - 198912
    SUZUKISWIFT Mk II Hatchback (EA, MA)198903 - 200312
    SUZUKISWIFT Mk II Saloon (AH, AJ)198903 - 200105
    SUZUKIBALENO Hatchback (EG)199503 - 200205
    SUZUKIBALENO Saloon (EG)199503 - 200205
    SUZUKIBALENO Estate (EG)199608 - 200205
    SUZUKIJIMNY (FJ)199809 - /
    SUZUKIGRAND ESCUDO (FT, GT)199803 - /
    SUZUKIWAGON R+ (MM)200005 - /
    SUZUKIIGNIS (FH)200010 - 200512
    SUZUKIAERIO (ER)200110 - /
    SUZUKIIGNIS II200309 - /
    CHRYSLERVOYAGER Mk II (GS)199501 - 200103
    CHRYSLERVOYAGER Mk III (RG)200002 - /
    SUBARUVIVIO199203 - 199812
    PERODUAKELISA (L7_)200202 - /
    PERODUAKENARI (L9_)200010 - /
    DAIHATSU CHARADE (G10)
    DAIHATSU CHARADE Mk II (G11, G30)
    DAIHATSU CHARADE Mk III (G100, G101, G102)
    DAIHATSU MIRA Mk II (L80, L81)
    DAIHATSU MIRA Mk III (L201)
    DAIHATSU CUORE IV (L501)
    DAIHATSU CUORE V (L5)
    DAIHATSU HIJET Bus
    DAIHATSU HIJET Box
    DAIHATSU HIJET Bus (S85)
    DAIHATSU HIJET Box (S85)
    DAIHATSU MOVE (L6, L9)
    DAIHATSU SPARCAR Bus (S7_)
    DAIHATSU SPARCAR Box (S7_)
    MITSUBISHI COLT (A15_A)
    MITSUBISHI LANCER F Mk II (A17_)
    MITSUBISHI LANCER (A17_)
    NISSAN MICRA I (K10)
    SUBARU JUSTY Mk II (JMA, MS)
    SUBARU JUSTY III (G3X)
    SUZUKI BALENO (EG)
    SUZUKI BALENO Hatchback (EG)
    SUZUKI BALENO Estate (EG)
    SUZUKI JIMNY (FJ)
    SUZUKI SWIFT Convertible (SF413)
    SUZUKI SWIFT (AA)
    SUZUKI SWIFT Mk II Saloon (AH, AJ)
    SUZUKI SWIFT Mk II Hatchback (EA, MA)
    SUZUKI WAGON R+ (MM)
    TOYOTA COROLLA (KE)
    TOYOTA COROLLA Hatchback (KE, TE)
    TOYOTA COROLLA Combi (KE)
    TOYOTA COROLLA Coupe (KE)
    MANUFACTURER REFERENCES (OEM CODES)
    - OTHER BRANDS : FTS 234.88 - FTS 116.90
    - OTHER BRANDS : 3044.90
    - OTHER BRANDS : A.454.87 - 6.302.88
    - OTHER BRANDS : 5101199Q
    - SUZUKI : 17670-50G10 - 17600-85821
    - SUBARU : 21200-KA151 - 17600-85821
    - NISSAN : 21200-01B00
    - DAIHATSU : 16341-87795-000 - 16341-87583-000 - 16341-87208-000
    Loki-TLR likes this.
    Silver Subscriber Tuckshop Ted's Avatar
    Jan 2006
    Stevenage, Hertfordshire, England
    6,062
    - Slow day?
    CrashB likes this.
    Red, the ONLY Colour.....1997 TLS.....
    'Gixxer Gold on Black Radial forks, Aftermarket Gixxer front mudguard - in red, Gold 4 pad Radial Toks, braided steel lines all round, Gold Nissin 19mm radial front brake master cylinder,
    Gold Nissin 19mm radial clutch master cylinder with Full Hydraulic clutch, Dunlop qualifiers, Baglux in red, Full Yoshi S/S race system & RS3 Gold Titanium oval cans, HID headlights, PC11, Custom map, K&N filter, Ohlins rear - pure gold, +2 rear sprocket, Metmachex swingarm, Cut back black double bubble screen &MotoX bars in gold, waterproof digital clock, R&G Crash bungs, Clear rear lens, LED Tail light with integrated turn signals, Colour match Undertray and Hugger, billet window clutch cover & plate spinner, gold Titax shorty levers, gold rearsets, Skidmarx bellypan, Low profile rear seat hump..all round (literally) nice guy.
    currently building up a TLR engined UNO frame and swingarm with TLS body - totally custom paint and parts..........
