| The Press Room ***Spoiler Warning*** This forum contains motorcycle news. Everything from MotoGP, World Superbike, and the Motorcycle Industry. Treat every thread as a spoiler, labelled as a spoiler or not. |
01-16-2010, 07:15 PM
Member #16322
Sportsbike: All
Riding Experience: 1
Life Wasted on TLZone: -
Asphalt & Rubber
Motus MST-01: Direct Injection, 2 Valves per Cylinder, 1605cc, 140hp, Made in America
This article comes from AsphaltandRubber.com
Motus Motorcycles has trickled out a bit more information about its Made in America MST-01 sport-tourer, giving CycleWorld their obligatory first look. What do they have to report? A 1650cc V4 motor with two valves per cylinder that features direct injection, which sums up to equal 140hp. More on that and photos after the jump.
If you forgot everything you know about the Motus MST-01 to-date, and approached the motorcycle motor from a mechanic’s perspective, you might mistaken the V4 motor for half a Corvette. Laid out just like an American-built V8, the large reason for the similarities is because the Motus MST-01 motor was designed by Katech, makers of the Corvette Z06’s 600hp V8 powerplant.
For us, looking at the Motus spec sheet, with its two valve push rod design, forwardly located water pump, and longitudinal configuration, it’s exactly what we’d expect to see from a company that talks in car every day.*Designed to be like a small American sports car, we see both strengths and weaknesses in this design philosophy.
Direct Injection has been around for ages, but just recently it’s become all the buzz in the auto industry. Refined by the American auto manufacturers, this method of getting fuel into the cylinder (the name really says it all) provides for greater efficiency in cylinder combustion, which crudely equates to getting more out of less. For instance, this translates into six-cylinders, which can now do the work done by larger eight-cylinders, etc.
Theoretically, Motus’ gasoline direct injection (GDI) system should allow the Motus MST-01 motor to make more power than a traditional two valve motor of similar size. However this doesn’t necessarily translate into comparisons against modern four valve motors.
Despite the MST-01’s nearly 450cc displacement advantage over the Honda VFR1200F’s four valve motor, the MST-01 makes nearly 20% less power. Of course maximum horsepower output is not the be-all end-all of judging the success of a motor’s design, and we have yet to see how smooth or torquey the MST-01 could be, but it’s an interesting insight into the Motus mindset.
The MST-01 will be the first production motorcycle to use direct injection, which is a technology you can bank on seeing trickled into the motorcycle industry over the coming years. However as with so many other American motorcycle startups, the hot rod mentality that brought us “there’s no replacement for displacement” seems to still prevail. This thought process, which has become the ethos for American manufacturers may resonate well with the baby-boomer generation, but is also indicative of the single-minded line of reasoning that collapsed three two of America’s auto conglomerates.
Is Motus (Latin for motion) moving forward or spinning its wheels in the past? With Motus squarely pegging perhaps the industry’s pinnacle of forward-thinking (at least in the ICE realm), the Honda VFR1200F as its mark to beat, the Alabama-based company certainly is setting the benchmark high. Time will tell if they meet that mark.
Visit Asphalt & Rubber for more articles like this one
01-16-2010, 07:23 PM
Member #11561
Sportsbike: 98 TLR just looks like an '02
Riding Experience: 26 Yrs
Life Wasted on TLZone: 5 Months, 2 Weeks, 6 Days and 12:06:42 Hours
ITSMESTEVE
's family coat of arms
ties in the back
That's a lot of motor for 140hp.I guess it pulls like a 14 yr old from idle?
Red 98 TLR but looks like a yellow 02.Full Yoshi system ,airbox mod,Bitubo rear,SS brake lines,SteveTLS TRE,TLRstacker Sliders,Rifleman 1/5 throttle,Vandriver swingarm pivots ,Pazzo levers,Vandriver tailrisers,PowerCommander lll,Projector headlights,GSXR forks and Radial Calipers & M/C,Ring-In 30mm offset triples,Duc radial clutch master,Ohlins steering damper...and counting. ........ PICK THE POINT IN THE SIG WHERE I JOINED TLZ
01-17-2010, 07:18 AM
Member #9502
Sportsbike: 02 TL1000R, 00 TL1000R, 97 TL1000S
Riding Experience: 14
Life Wasted on TLZone: 1 Month, 0 Weeks, 0 Days and 4:09:49 Hours
TLR-Brendan
I guess if you're building a touring bike torque is what you want.
2002 TL1000R, Air box mod, Pipercross air filter, Full yoshimura RS-3 stainless, Yoshimura box remap. R-1 throttle tube, Bitubo rear shock, Vandriver billet rear resovoir, tail risers, +1mm swingarm eccentrics, sprocket cover.
Future plans. 12.6:1 pistons, Web cams and gears, PCIII, Matchported and cleaned up heads, Vandriver triple clamps and clutch cover...
SOLD2004 GSX-R 1000, K&N air filter, Full yoshimura carbon TRS exhaust, -1 front sprocket. 148.3 horsepower and 73.14 ft-lbs torque.
2000 TL1000R track bike. K&N air cleaner, yoshimura RS-3 carbon full system with dual oxygen sensor bungs. Stock engine for now......
1997 TL1000S, soon to be TLR powered....
01-17-2010, 07:38 AM
Life Wasted on TLZone: 3 Months, 3 Weeks, 4 Days and 21:11:35 Hours
I like it - a bit different thinking and just might work well. I'd guess it has the potential to use drastically less fuel than most current motorcycles. My biggest concern is packaging - its hard to tell, but the motor might be a bit on the tall/wide side of things. Borrowing a cue from the corvette isn't the worst thing they can do. I can't think of any other cages with the same sort of power and efficiency (430hp and 26mpg or 505hp and 24mpg or 638hp and 20mpg).
BTW I think it is quite incorrect to say that a focus on displacement led to the downfall of the US auto industry. Funky regulations more than anything else did it. Even looking at displacement and fuel economy, the US makers tend to make vehicles that are more efficient than the others rather than less if you look at the areas where they focus (typically trucks and larger vehicles - the us makers for the most part only messed about with small cars after forced to by arcane rules dictating that all mfg's meet average fuel economy specs regardless of whether one specialized in econ-boxes and another trucks). This prevented the us mfg's from specializing exclusively in their area of strength. Then the second big problem was the unions - they were insanely powerful and went to great lengths to drive up mfg'ing cost and reduce productivity.
