| The Press Room ***Spoiler Warning*** This forum contains motorcycle news. Everything from MotoGP, World Superbike, and the Motorcycle Industry. Treat every thread as a spoiler, labelled as a spoiler or not. |
01-06-2010, 01:25 PM
Member #16322
Sportsbike: All
Riding Experience: 1
Life Wasted on TLZone: -
Asphalt & Rubber
Krisfox’s Ducati Hypermotard 1098S
This article comes from AsphaltandRubber.com
In the hands of one Frenchman, what began life as a mild-mannered Ducati 1098S Superbike, has turned into a water-cooled Hypermotard that would do the engineers in Bologna proud. Known to us only as “Krisfox”, this builder was looking for more than the standard streetbike experience. Wishing to see the more powerful water-cooled 1098 motor in a motard format, he set out to make one of his own, dubbed the Hypermotard 1098S. Pictures and more after the jump.
The bike is built around the standard 1098 frame and motor, but that’s pretty much where the resemblances stop. Since the Hypermotard panels and accessories do not bolt-up to the 1098 framework, Krisfox had to custom fabricate nearly every other part. Hand crafting all the bodywork from foam and clay, the HM 1098S was finally laid-up in beautiful carbon fiber panels, which were painstakingly built to accommodate the bevy of parts this bike boasts.
For instance, things like the gas tank had to be re-built, which allowed for improvements to be made. As such, the HM 1098S’s tank now holds over 4.8 gallons, which should be good for more than a jaunt down the road. Helping things go faster are a custom airbox, with carbon air intakes and a pair of undertail style Akrapovic exhausts cans help*expel the gases. These parts bring the bike’s power figured into the 165hp range, and with a 169kg (373lbs) weight, that’s nearly a metric 1:1 ratio. Completing the look of the bike is a carbon fiber chin, à la Ducati Streetfigher, making this bike a looker and a power house.
The HM 1098S would not be complete without some aftermarket goodness, and as such Öhlins R&T forks have been added up front, while an Öhlins TTX shock in the rear gives this Ducati some of the best street suspension money can buy. Helping shave off the unsprung weight are carbon BST wheels, clad with Pirelli Dragon Supercorsa tires. To stop all this two-wheeled goodness, radial Brembo mono-bloc brakes have been employed, thus completing the Holy Trinity of aftermarket motorcycle goodness (Öhlins, BST, Brembo).
How does it ride? According to the owner:
“It accelerated like a ball. In slow corners it has crazy handling like a 600 supermoto, and on the road its like a Ducati SBK…I am thrilled, I realized the bike of my dreams.”
If rumors are true about Ducati phasing out its air-cooled two-valve lumps, we very well could be staring into the future of the Hypermotard line….and we like it.
Visit Asphalt & Rubber for more articles like this one
01-06-2010, 01:34 PM
Life Wasted on TLZone: 3 Months, 3 Weeks, 4 Days and 11:15:01 Hours
Just needs the DP seat
01-06-2010, 02:13 PM
Member #785
Sportsbike: Tillis, What else?
Riding Experience: A bit more than it was
Life Wasted on TLZone: 1 Month, 3 Weeks, 6 Days and 3:05:27 Hours
tls-moose
Brilliant concept, but can't help but think it was done the wrong way - why not just fit the 1098 motor to the Hypermotard chassis  there's something that just doesn't quite gell aesthetically for me, and I can't figure whether it's the very low front end or the "density" of the centre of the bike
Done: Fat-bar conversion; DNA Handlebar fairing; TLR Clock conversion; Yosh TLR Headers, one-off link pipes & Carbon cans; Relocated oil cooler; Relocated Coolant bottle; Transistor TRE; PCII; +1/-1 sprockets; Hyperpro steering damper & 916 style mount; Maxton Re-Valved forks; Tokico 6 pot callipers; HEL braided hoses; TLR Swing-arm; Bitubo shock; Yellow Box; 98+ Thermo-mod; JarkkoT +/- mod; Airbox mod; K&N air filter; Riflemans 1/5th; Harris carbon mudguard; Carbon Solo Seat Unit; Pyramid undertray; Powder coated wheels; Mini indicators; LSL rearsets; Scotoiler
01-06-2010, 05:11 PM
Never ride faster than your angel can fly.
Member #17601
Sportsbike: 97' TL1000s (v)
Riding Experience: Getting better every day.
Pictures: 6
Life Wasted on TLZone: 1 Month, 3 Weeks, 5 Days and 10:57:15 Hours
Chris
If it ain't broken don't
fix it, it cost too much.
I'm in love  this is lurverley
01-07-2010, 01:52 AM
Member #144
Sportsbike: '09 KTM 990 SM-T
Riding Experience: 10 years
Life Wasted on TLZone: 2 Weeks, 0 Days and 3:47:50 Hours
wreckah
is quite fit, but he'll die
puuuurfect...
apart from the battery up front  com'on, there must be another way to place the battery! all that money, and then that eyesore!
01-07-2010, 02:00 AM
Member #7934
Sportsbike: 98TL1000S
Riding Experience: 30+
Life Wasted on TLZone: 1 Month, 1 Week, 3 Days and 0:28:43 Hours
Big Red
needs a holiday !
As you've said moose ,love the idea but something just doesn't fit for me either .
FP levers ,Leo Vince cans ,Bitubo ,Suspension Tech valves ,Eibach springs ,Ohlins steering damper ,Barnett clutch springs ,K&N air filter ,flapper valve and associated shite removed ,Irridium plugs ,PC11 ,Loweys TRE ,Charging mod ,Jarkkos plus mod , DavCruz fan switch mod ,Six pots ,Braided lines ,Riflemans ccc ,The Ring Ins modded pressure plate ,dropped one tooth on the front sprocket ,Van drivers sprocket cover ,TLR engine breather/separator .
Wish list: Does it ever end ?
01-07-2010, 08:11 AM
Member #2230
Sportsbike: 2003 Yamaha FZ1, 1998 KTM 250 EXC, Suzuki Bandit 400
Riding Experience: 9
Life Wasted on TLZone: 1 Month, 3 Weeks, 4 Days and 3:03:04 Hours
gixxerjasen
Sits too low for a motard, that's what I see. Still, a sweet ride none the less.
www.leanangle.com
Current Bikes: 2003 Yamaha FZ1 | 1998 KTM 250 EXC | Suzuki Bandit 400-Sold and bought back again
Past Bikes: 1997 Katana 600-wrecked | 2000 CBR600F4-Stolen | 2001 GSX-R600-Stolen | 1989 Honda CB1-Sold | 2001 Suzuki TL1000R-Traded | 2004 Suzuki GSX-R600-Sold | 2007 DR-Z400SM-Traded
A Kourier has to establish space on the pavement. Predictable law-abiding behaviour lulls drivers. They mentally assign you to a little box in the lane, assume you will stay there, can't handle it when you leave that little box.
Y.T. is not fond of boxes. Y.T. establishes her space on the pavement by zagging mightily from lane to lane, establishing a precedent of scary randomness. Keeps people on their toes, makes them react to her, instead of the other way round.
- Neal Stephenson
01-07-2010, 09:00 AM
Member #14819
Sportsbike: 2003 TLR
Riding Experience: 3years
Pictures: 5
Life Wasted on TLZone: 1 Week, 1 Day and 13:41:58 Hours
Tiller13
nice bike could make for some spirited riding...
...Elbowz aka Alien#5...
2003 TLR Mods: Full Yosh RS3..K&N..Airbox Lid Removed with Joe V Mod..A&R TRE..Charging Mod..Plus Mod..PCII..EBC Pads..Driven Grips..Xenon HID Bulbs..Dunlop Qualifiers..530 Conversion 16/40..Custom Paint and Decals..
...its not how much horsepower you have but how much you are willing to use...
01-08-2010, 12:40 AM
Sold, to the man in the slippers
Member #6383
Sportsbike: TLR 1000 (of course).
Pictures: 20
Life Wasted on TLZone: 3 Weeks, 4 Days and 8:28:58 Hours
bentlr666
Looks like a Monster with hypermotard bodywork.. Still looks like fun though
TLoM here i come.... ok it may take me a while but i'm working on it
Work in Progress.....
Vandriver's Clear Clutch Cover, Pressure Plate, Sprocket cover, Billet Rear Brake Reservoir and Brake Return Spring, Yoshi RS3 SS Bolt on's, +2 Driven Rear Sprocket, Eaglescreens Blue Windlip Screen, Revolution Rotors, Axle Flip Mod, MattTheHat TRE, Bitubo Rear Shock, Rifleman's 1/5th Insert, FP Racing Lever's, Charge Mod, Carrozeria V-Track Wheels, Tribo Seat Cover
Waiting to be installed...
Gap Mod Tray, TopGun Undertail
01-08-2010, 03:34 AM
Member #1415
TLR-Billbo
is dreading winter coming
* 2005 SXR 800*Skat 9/17 140-75 SS Impeller*Blowsion mat kit*Blowsion billet bilge switch*Rule 500GPH bilge*R&D bilge bracket*R&D billet angled reed spacers*V-Force Delta 2 Carbon reeds*R&D exhaust sleeve*Wamiltons scupper*Wamiltons stubby pump cone*fuel fill and pickup mod*-4" hull*-1.5" pole*R&D stealth intake grate*-4" ride plate*ODI grips*R&D Pro-lock filters*Jetworks mixture screws*Blowsion billet engine mount keepers*R&D 6º ignition adv kit*Billet driveshaft coupler*dual-cooling*Wiseco 80.96mm factory Kawi race pistons (true 800cc)*UMI Billet throttle lever*
MySpace and Facebook
Originally Posted by Shrek
