Hi,
Due to the lack of power on my bike compare to 1098 DUC's race bikes, I am obliged to developp new solution in way to improove the engine efficency. I remember you, that I have arlready inside :
* Specific camshafts with vernier
* Head flowed job
* five angles on seat valves job
* Squish setted and compression ratio at 13.5:1
* Hermit dragon air box in carbon
* PC II with specific map optimized for the full throttle position
* 2 in 1 full exhaust in 57 mm
* Yoshimura magneto rotor 1 phase ultra light (350gr with ignition bracket!
* 100 LL fuel gas
* No engine motor starter, no free wheel, when I'll have the time I wil take some pics of that
With that I have roughly 152 HP in the cranck, but there is still a big gap with 189 HP of DUC's, so I have choose the way like us to over bore my cylinder, and I project to put new pistons in 105 mm thanks to JE R&D who can supply me with this specific bore, and with suitable specs according my motor configuration. For this, My idea is to remove the Nikasil and to install an iron liner with an external diameter of 112 mm and then bore to 105 mm. The cranckcase hole is 114mm, so what do you think?
I am waiting your scientific comments!
