***RACE UPGRADE ON TLR MOTOR*** - Page 15 - TLZone Forums
Go Back   TLZone Forums > The Workshop > Performance Enhancement
Performance Enhancement Things that make you go VRRROOOOM!
Old 11-20-2009, 05:52 AM   #141 (permalink)
Sam Sam is online now
Trader Rating: (104)
Life Wasted on TLZone: 2 Months, 4 Weeks, 1 Day and 15:25:36 Hours
Originally Posted by fofo#85 View Post
Due to that, I will be never ready to run in 2010!!!
Have you ever seen a stuff like this?[/IMG]
It was done after a normal engine warm up at 3K rpm!
Unfortunately cracked cam buckets are a very common problem, always the exhaust on the front cylinder, do a thread search, lots of examples
Old 11-20-2009, 08:20 AM   #142 (permalink)
rufer's Avatar
Member #1366
Riding Experience: Since 1999
Trader Rating: (33)
Life Wasted on TLZone: 3 Weeks, 6 Days and 5:39:35 Hours
rufer
Send a private message to <!-- google_ad_section_start(weight=ignore) -->rufer<!-- google_ad_section_end --> Steve is the prettiest admin
In Germany this problem is well known even on street engines! It's always a front exhaust bucket that fails.
It gets a lot worse with tuned engines (too much cam lift, too hot cams). My biggest opponent in the TL Cup blew his engine twice in one race season. In both cases it dropped a valve just after warmup.
Failed valve bucket tappets?
Old 11-20-2009, 11:05 AM   #143 (permalink)
gixxstar's Avatar
Member #3743
Sportsbike: GSX-R750 TLR1000
Riding Experience: streetrider/roadracer
Trader Rating: (23)
Life Wasted on TLZone: 2 Weeks, 0 Days and 11:53:34 Hours
gixxstar
Send a private message to <!-- google_ad_section_start(weight=ignore) -->gixxstar<!-- google_ad_section_end --> Steve is the prettiest admin
I've never had one fail and this is the only other place I've seen it mentioned.
Old 11-20-2009, 06:30 PM   #144 (permalink)
fofo#85's Avatar
Member #1365
Sportsbike: JLSV 10.8
Riding Experience: 18 years
Life Wasted on TLZone: 1 Day and 16:30:10 Hours
fofo#85
Send a private message to <!-- google_ad_section_start(weight=ignore) -->fofo#85<!-- google_ad_section_end --> Steve is the prettiest admin
I am unfotunately glad to see it wasn't a special case... But what does it mean? Why we have this kind of problem at each time on the same place? Un my case I have plan to put new tapets, but is it a safe solution? It makes a lot of questions! But thanks to all!
Forever with TL1000R heart !!! <a href=http://i5.photobucket.com/albums/y167/fofo85/protwin.jpg target=_blank>http://i5.photobucket.com/albums/y16...85/protwin.jpg</a>
Old 11-21-2009, 06:58 AM   #145 (permalink)
doug's Avatar
Member #221
Life Wasted on TLZone: 3 Days and 20:34:08 Hours
doug
Send a private message to <!-- google_ad_section_start(weight=ignore) -->doug<!-- google_ad_section_end --> Steve is the prettiest admin
Yes just put in some new buckets and the problem is solved. On used engines if you check the cam buckets carefully from time to time you will see the buckets starting to go before they break up completely. I have changed out the buckets on the last race engine that I put together as the parts where used and would have let go. ON the first race engine I built which does not have high lift cams just stock ones and a fair number of miles on the street and the track no problems. Seems more pronounced when the engine has high lift cams.
Old 11-21-2009, 08:05 AM   #146 (permalink)
fofo#85's Avatar
Member #1365
fofo#85
So thanks Doug! Now I hope I will never met again this kind of troubles, so I will include this clearance in my race check list.
