Future FAQ Wheel matches - Page 2 - TLZone Forums
Go Back   TLZone Forums > The Workshop > Performance Enhancement
Performance Enhancement Things that make you go VRRROOOOM!
Old 09-25-2003, 11:10 PM   #11 (permalink)
Rudedog's Avatar
Member #442
Sportsbike: 97 TLS
Riding Experience: 15+
Trader Rating: (6)
Life Wasted on TLZone: -
Rudedog
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Rudedog<!-- google_ad_section_end --> Steve is the prettiest admin
13lbs
Old 09-28-2003, 07:03 AM   #12 (permalink)
Slapper's Avatar
Member #200
Sportsbike: '06 Suzuki GSX-R750
Riding Experience: 20 years
Trader Rating: (7)
Life Wasted on TLZone: 0:04:30 Hours
Slapper
Send a private message to <!-- google_ad_section_start(weight=ignore) -->Slapper<!-- google_ad_section_end --> Steve is the prettiest admin
I agree. I'd have to say:
The Slapper
'03 TL1000R
http://my.core.com/~photos/all.your.....2.new.sig.jpg
Old 09-28-2003, 08:42 AM   #13 (permalink)
WSB Pit boss
oneeviltwin's Avatar
Member #13
Sportsbike: 2002 TL1000rr
Riding Experience: since 1983
Trader Rating: (35)
oneeviltwin
Send a private message to <!-- google_ad_section_start(weight=ignore) -->oneeviltwin<!-- google_ad_section_end --> Steve is the prettiest admin
the rims are gixxer 1k or 750 the 600 rear is a 5.5 unless your running 180 they'll be fine,as for the weight i have no hard proof on the weight advantage.but let me see if i can find some info on it.if it aint true then i'll be then first to say ive been had, since that is what i wastold and that is why i did the conversion.so for now let it be known that it could be bullshit.
MY MODS:
Ackrapovic Evo II full exhaust Head Work,Flowed injectors,Port /Polish exh and intake.cams,subframe,projector headlights,gap mod,Undertray,air/oil breather,pair valve removal,black frame Earth grounding mod . Dynojet PowercommanderII: (Custom Map by Orient Express):Galfer Wave Rotors Front & Rear: Pyramid Hugger:GSXR1k rear brake:A.T.R.E,Galfer Steel braided lines Front & Rear:TLS Cable Clutch Conversion:Woodcraft clipons:Vortex top triple clamp: DID Erv2 gold 520 conversion: Spocket Specialist Titan Tough Sprocket 17/41:GSXR tail: Nocut Frame Sliders:Air Tech Black Chrome Windscreen:LP Carbon Mirrors:Raised Tail 3/4" Ohlins Steering Damper:BRG 1/5 Throttle:GP Tech Fairing Bracket: Clear Alternative tail light:Black rims, ProTeck rearsets.gixxer 1k fender.Bitubo shock,custom projector headlights Race plastics and air tubes by AK composite 3/4 tail rasier custom made by TLDV8
Going For 440 wet weight.136 +HP. 72 +TQ
TO BE CONTINUED
Old 03-25-2004, 01:59 AM   #14 (permalink)
Sam Sam is offline
Trader Rating: (104)
Life Wasted on TLZone: 2 Months, 4 Weeks, 1 Day and 14:54:18 Hours
Hayabusa Rear fits, but beware that the brake disc diameter is larger and the cush drive spindle spacer is shorter
I noticed this after having new spacers made for my marchesini, with dimensions calculated from a Hayabusa wheel cos I couldn't be bothered to remove the rear from my TLS
Old 03-29-2004, 09:57 PM   #15 (permalink)
MotoGP Pit Boss
horkn's Avatar
Member #255
Sportsbike: 97 tls
Riding Experience: 14 years street, 15 dirt
Trader Rating: (16)
horkn
Send a private message to <!-- google_ad_section_start(weight=ignore) -->horkn<!-- google_ad_section_end --> Steve is the prettiest admin
hmm, look at the part nos.. they are the smae for tls tlr and hayabusa... i looked at my ex roomies 02 busa wheels once, and they were the same... exactly
http://img.photobucket.com/albums/v6...poopbanana.gif
apparently my old sig pissed some people off....
Old 03-29-2004, 11:06 PM   #16 (permalink)
Sam Sam is offline
The Part Numbers are :-
TL Rear Disc 69211-33E10
Hayabusa Rear Disc 69211-21E00
TL Spacer 64751-33E00
Hayabusa Spacer 64751-24F00
I could be wrong, but the part numbers suggest otherwise
Old 04-06-2004, 06:18 AM   #17 (permalink)
jack47's Avatar
Member #2048
Sportsbike: TL1000R (track), 2003 Aprilia Tuono Racing (street), KTM450exc (dirt)
Riding Experience: 11 yrs
Trader Rating: (10)
Life Wasted on TLZone: 2 Days and 14:24:44 Hours
jack47
Send a private message to <!-- google_ad_section_start(weight=ignore) -->jack47<!-- google_ad_section_end --> Steve is the prettiest admin
Has somebody weighed those stock rims yet? I would love to hear what the real weight difference is!
2000 TLR
Full yosh system
Hyperpro steering damper
Ohlins rear shock
K&N filter
PCII
Carbon fender
Tre
Traxxion reworked forks (with racetech internals)
Vandriver +2 swingarm pivot
520 kit with stealth sprocket
1/5 turn throttle
EBC Pro-lite Race rotors
stainless lines
Attack adjustable tripples
Brembo 19x18 master
Sebimoto carbon race bodywork
CFM rearsets
Double Bubble light smoke
Old 04-06-2004, 06:22 AM   #18 (permalink)
GXRKLR's Avatar
Member #521
Sportsbike: Black DL 1K, Blue '02 R1, '95 250 Ninja
Riding Experience: Rough
Life Wasted on TLZone: 1:20:38 Hours
GXRKLR
Send a private message to <!-- google_ad_section_start(weight=ignore) -->GXRKLR<!-- google_ad_section_end --> Steve is the prettiest admin
Rear TLR rim and rotor are 15.7 lbs hub is 3.9 lbs and the OEM rear sprocket is 1.9 lbs. I didn't weigh the cush drive.
RIP Ron
Sept. 12 2004
http://img.photobucket.com/albums/v1...KLR/RonRIP.jpg
Old 04-21-2004, 07:52 AM   #19 (permalink)
BikePilot's Avatar
Trader Rating: (18)
Life Wasted on TLZone: 3 Months, 3 Weeks, 4 Days and 14:25:17 Hours
I mounted wheels from a 2000 gixxer 600 (the last of the srad series with the rounded spokes like the tl) and they bolted up without any modifications. The rear is a 5.5 inch, the front is the same, but the colour matches the rear
Old 09-22-2004, 08:40 PM   #20 (permalink)
Motarded
GT80's Avatar
Member #4
Sportsbike: '97 TLS, '05 DRZ400SM
Riding Experience: 25 and counting....
Trader Rating: (20)
Life Wasted on TLZone: 3:55:59 Hours
GT80
Send a private message to <!-- google_ad_section_start(weight=ignore) --><b>GT80</b><!-- google_ad_section_end --> Steve is the prettiest admin
I'm always looking for a deal on aftermarket wheels and they're usually hard to find advertised for TLS's specifically. I'd like to know what other wheels will interchange. I've read this thread and can't really decipher a lot of the stuff posted here.
Here's a question. What other Suzuki wheels will fit a '97 TLS (same brake rotors)?
TL Zone Forums Staff - Resident Weenie
damper - A device that eliminates or progressively diminishes vibrations or oscillations
dampener - A device that dampens or moistens something
dampner - Not even a friggin' word!!
Some people are like Slinkies...Not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
